6500 slipping clutch (only 250 hrs)
   / 6500 slipping clutch (only 250 hrs) #21
</font><font color="blue" class="small">( i'd hate to see someone going in high 4 reverse though /forums/images/graemlins/smile.gif . )</font>
I bet James Bond OO7 could do it with ease!
   / 6500 slipping clutch (only 250 hrs) #22
Tim, I was wondering if the bolt pattern was different for the trans hookup for the 6500 vs. 6000. IOW, does the 6500 require a different trans "body"? Hence the leaking into the clutch area...bobg in va
   / 6500 slipping clutch (only 250 hrs) #23
I've got a service manual at home. I'll have to check...
   / 6500 slipping clutch (only 250 hrs) #25
I dont recall specifically. I got the service and the parts manual and I think together it was in the $140-160 range. Make sure if you have the 6500 that you get the addition for it in the service manual.
I have put 50 hrs on it since it came back and it is just like it was when new. (hopefully better) My front tires are only out a little ways, rear tires were out all the way. I have moved the right rear in one spacing. When square baling on some of my wet ground running on the windrow was not a good thing.
Will
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2019 FORD F-350 (A52472)
2019 FORD F-350...
2014 Ford Taurus Sedan (A51694)
2014 Ford Taurus...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
