6500 slipping clutch (only 250 hrs)
   / 6500 slipping clutch (only 250 hrs) #21
</font><font color="blue" class="small">( i'd hate to see someone going in high 4 reverse though /forums/images/graemlins/smile.gif . )</font>
I bet James Bond OO7 could do it with ease!
   / 6500 slipping clutch (only 250 hrs) #22
Tim, I was wondering if the bolt pattern was different for the trans hookup for the 6500 vs. 6000. IOW, does the 6500 require a different trans "body"? Hence the leaking into the clutch area...bobg in va
   / 6500 slipping clutch (only 250 hrs) #23
I've got a service manual at home. I'll have to check...
   / 6500 slipping clutch (only 250 hrs) #25
I dont recall specifically. I got the service and the parts manual and I think together it was in the $140-160 range. Make sure if you have the 6500 that you get the addition for it in the service manual.
I have put 50 hrs on it since it came back and it is just like it was when new. (hopefully better) My front tires are only out a little ways, rear tires were out all the way. I have moved the right rear in one spacing. When square baling on some of my wet ground running on the windrow was not a good thing.
Will
City of Lakeland (A51691)
City of Lakeland...
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
