6500 slipping clutch (only 250 hrs)
   / 6500 slipping clutch (only 250 hrs) #21
</font><font color="blue" class="small">( i'd hate to see someone going in high 4 reverse though /forums/images/graemlins/smile.gif . )</font>
I bet James Bond OO7 could do it with ease!
   / 6500 slipping clutch (only 250 hrs) #22
Tim, I was wondering if the bolt pattern was different for the trans hookup for the 6500 vs. 6000. IOW, does the 6500 require a different trans "body"? Hence the leaking into the clutch area...bobg in va
   / 6500 slipping clutch (only 250 hrs) #23
I've got a service manual at home. I'll have to check...
   / 6500 slipping clutch (only 250 hrs) #25
I dont recall specifically. I got the service and the parts manual and I think together it was in the $140-160 range. Make sure if you have the 6500 that you get the addition for it in the service manual.
I have put 50 hrs on it since it came back and it is just like it was when new. (hopefully better) My front tires are only out a little ways, rear tires were out all the way. I have moved the right rear in one spacing. When square baling on some of my wet ground running on the windrow was not a good thing.
Will
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
LOT LOCATIONS (A54313)
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
