6500 slipping clutch (only 250 hrs)
   / 6500 slipping clutch (only 250 hrs) #21
</font><font color="blue" class="small">( i'd hate to see someone going in high 4 reverse though /forums/images/graemlins/smile.gif . )</font>
I bet James Bond OO7 could do it with ease!
   / 6500 slipping clutch (only 250 hrs) #22
Tim, I was wondering if the bolt pattern was different for the trans hookup for the 6500 vs. 6000. IOW, does the 6500 require a different trans "body"? Hence the leaking into the clutch area...bobg in va
   / 6500 slipping clutch (only 250 hrs) #23
I've got a service manual at home. I'll have to check...
   / 6500 slipping clutch (only 250 hrs) #25
I dont recall specifically. I got the service and the parts manual and I think together it was in the $140-160 range. Make sure if you have the 6500 that you get the addition for it in the service manual.
I have put 50 hrs on it since it came back and it is just like it was when new. (hopefully better) My front tires are only out a little ways, rear tires were out all the way. I have moved the right rear in one spacing. When square baling on some of my wet ground running on the windrow was not a good thing.
Will
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
