7,000# vs 10,000# trailer
   / 7,000# vs 10,000# trailer #91
Not sure what you mean by that. If I were towing a 2500lb tractor I would rather it be on my new trailer for sure than the old one. No question which one is more secure and the new rides way better.
A light load isn t going to work the suspension of the heavier rated trailer. Thus the load won t ride as smooth. Bigger isn t always better. Take a ride in a 1 ton pickup and then a 1/2 ton and see which one rides better with little or no cargo. Same applies to a trailer. The springs on that heavy trailer will hardly be useful. Now if you throw a heavy load on that same trailer, that s a different story. You put your little 2500 lb. tractor on a 10 or as you put in your comment, no harm in even going 12k or 14k trailer, you would have zero trailer suspension going down the road. Definitely overkill on your trailer of choice for that application. Why someone would buy a 12 or 14k gvw rated trailer when a 7k trailer would be fine is beyond me. Kind of like buying a sledge hammer to drive carpet tacks!! At any rate,,,to each his own........Jim
   / 7,000# vs 10,000# trailer #92
Yesterday 11:55 PM
I can give you a perfectly good reason why I bought a 14K trailer.....because I have a 9500lb tractor to tow around. I'm not going to own 3 different trailers just because tomorrow the load my be lighter than today. Also I tow a variety of stuff and have no clue what tomorrows load might weigh. The 14K will cover 99% of what I tag onto. The old 7K was always overloaded even with a full size truck. Now if I have to go after just about any vehicle I'm covered by weight or space on the trailer. I hauled a 68 Chrylser 300 for my uncle last year that was 18' nose to tail. Completely filled the 7K trailer and rode light crap. That same car on my new one would have been a piece of cake and a whole lot safer. Sure if all I had was a little bitty CUT to haul and nothing else, but thats not the case here.
   / 7,000# vs 10,000# trailer #93
Mr Brown that setup should really work for you, I tow a 7000lb trailer with brakes at all wheels with a Dodge Dakota v8 with trailer package and haul my ck20 loader and backhoe all the time with absolutely no problems, drew the kioti home to Ontario from Tenn. this past summer . Gary
So when I go to the quarry, I can get 3 tons per trip instead of 1.5 tons.
Given the slight difference in cost/size/weight between a 7k and 10k trailer, I'd counter to wonder why someone would purchase a 7k capacity trailer unless that is really truly only what they would ever in their lives ever need.
My brother has a 24' enclosed 7k trailer and scaled at nearly 10k lbs in his last move. Not too tough to overload a trailer if you put some effort toward it. I'd rather have the higher capacity and not worry about it.
And we're not exactly transporting presidential china here...
All that said, 12k and 14k trailers are no joke. I probably wouldn't consider a trailer that heavy even if I had the truck to tow it. Those things are HUGE.
   / 7,000# vs 10,000# trailer #95
Actually when its all said and done I now tow and additional 2k with any load than I used to with the 7K. I figure the rolling resistance penalty is offset by larger tires and bigger axle. If I have a car for example on my current 14K vs the same car on my old 7k I only notice the extra weight on hills. On the flat it feels the same to me except for it rides alot smoother and steadier.
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
LIGHT TOWER (INOPERABLE) (A55745)
LIGHT TOWER...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 KENWORTH T660...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
