7000 ford
   / 7000 ford #1
robert109
fredericton,nb,canada
ford 7000,long350,ford4000,mf180
I am changing the oil and filter on my ford 7000,I notice that the new filter is 2 inches longer then the old one Old is 6in new is 8in,just wondering if that is ok ,I realize that it will require more oil to fill to full mark,Thanks
   / 7000 ford #2
Is the replacement filter Ford New Holland or aftermarket. Was the old filter after market or Ford NH? Suspect would not be a problem but curious if cross from two different manufacturers.
   / 7000 ford #3
The original filter for the turbocharged 7000 was larger than the filter on the naturally aspirated engine. It also had a check valve in it to keep oil in the turbo
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
1761 (A58375)
1761 (A58375)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
