Tires 790 Tires
/ 790 Tires #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
When I bought my used 790 tractor in December, I did not realize that there was another larger tire size offered on these models (ignorance is bliss...right?) and from the pics I've seen the difference appears fairly significant. Well, my tractor has some pretty small R1 tires and I was about to put fluid in the rears. The size is 12.4-16 R1. I ordered some tubes for it today...to protect the rims from the fluid I am adding....and hopefully add some additional protection with punctures in the woods.
About the only advantages I see is I have a somewhat improved center of gravity, possibly a little lower ground speed with my tiller, and chains would work better on it. But I wonder how much I am giving up in the traction department? :confused:
Just curious....anybody else have this size of tire on their 790? and how do they work for you in the pulling department? (i.e. disc or plow)
Thanks in advance. :)
/ 790 Tires #2
I have the same tires as you foggy, no complaints. They seem wider than the others, though shorter. The other big difference is the wheels. Ours are one piece and limited to two positions. The others are two piece with more adjustment options.
I haven't done a lot of ground engaging work, though I did borrow a 6 1/2 foot disc when we first got the property. It handled it surprisingly well.
/ 790 Tires
Thanks Rob. You mention the wheels having two positions.....and I have read that elsewhere. But I fail to see how these wheels could be made to go into any other position than the one they are in. I've looked at 'em every which way...and I dont think they can be inverted. (fronts? yes...did those...but not the rears).
And...good to know on the disc. Others have said all I will do is spin my wheels....but I bought a 5 1/2' KK box frame anyway....gonna load my 790 down with as much weight as I can....I figure to pull it too.
Anyway...thanks for the input. Been a long winter...and waiting to use this thing. ;)
/ 790 Tires #4
I have 11.2x24 in the rear and 7-14 in the front. I didn't know anything else was available on the 790 in R1's. I'm very happy with the traction I get with mine. I think my rear wheels have four positions.
/ 790 Tires
Evidently they did not offer those bigger tires when my tractor was built (01). My book shows either 12.4-16 or 13.6-16 for rears. I'm also not sure if they offered adjustable wheels or tires other than R1's. :confused: Mostly curious......as these are gonna do just fine, but....Anybody know?
/ 790 Tires #6
Your tractor must be about the same age as mine foggy. I recall seeing some on the lots at the time with the two piece rims as well as the one piece. Oh BTW, the two positions on ours are "as mounted" and "reversed". For reversed, you'd swap sides to keep the tread direction the same. I don't know how much offset there is, not much I think.
/ 790 Tires #7
I bought mine new last year so it was the last year for the 790, now the 3005. I didn't realize they put 16" wheels on the 790.
/ 790 Tires
Yeah, I've looked at that swap.....but, I didn't think it would work out. Today I am having tubes put in my rear tires and fluid added for stability and traction...so my local co-op will need to take the tires off the tractor. I am going to see if I can swap the right for left and pick up a few inches of extra width. I'll report back my findings....but I am not too optimistic.
Rob, I am not very good at understanding ag tire sizes....so, I'm not sure, but I think our wheel/tire combo has a bit more sidewall and less wheel than the current tires offered (and a bit more width).
Also, according to my manual I am only going to add about 450 lbs of calcium chloride in both rears....but on this size tractor, every bit helps. :D
/ 790 Tires #9
I had mine filled with Rim-Guard a couple of years ago. Weight seems about right, I think CaCl is bit more. Helped quite a bit, except on ice! Nice thing about Rim-Guard is no tubes and no rust.
/ 790 Tires #10
My 850 has 7-14 fronts. Does anyone know where I can get turf tires this size? All I can find are ag tires and they are really hard on my yard.
/ 790 Tires
My 790 4wd came with a spare set of turf's which are the same circumference as my front R1 ag tires. The guy before me used 'em across his yard to hold down the damage from the R1's. I had 'em changed back to all R1 tires. But if need to work on a lawn I will put them on. Lotsa people will warn you to make sure they are the same diameter and circumference so as to not wreck your 4wd. (Of course you could just operate in 2 WD with the turf tires....FWIW)
I'd check with a dealer. They oftentimes have take-offs or at least you can find out if they make em or offer anything to fit.
/ 790 Tires #12
Hello foggy, Input for original question, I have 11.2-24 with rim guard and 7-14 r-1 combo like meck, rear rims are two piece. I ended up with an old 3pt 6 foot cultivator and pulls it just fine in 5th, 6th gear. Other than a 8 foot two row marker, that is the widest tilling implement I have tried with the 790.
/ 790 Tires #13
You should be able to switch the rear tires and gain an inch in width. On my 3520, there is about an inch of difference. The valve stems point to the inside, for the wider stance. Doesn't make a lot difference, but every little bit helps.
If there is a way you can get away from running tubes, that would be better. The reason is that tubes have rapid air loss when punctured. If you have a tubeless tire, and you poke some thorns in there, the thorns will a lot of times plug the hole enough and you don't loose your air. When a tube gets punctured, the tire goes flat within a short period of time and you have calcium all over the place. I would recomend the rim guard as fluid, or wiper washer fluid, and no tubes.
Shouldn't loose much traction with smaller tires. They should actually give you a little more pull in the bottom end.
/ 790 Tires
Hmmm....that is pretty good advice on the tubeless tires.....but it's too late. I allready had the tubes put in and cal chloride added. Nobody around here (big farming community) offers anthing but the calcium chloride...so I went with that. I am going to ask around where I now have moved my tractor (200 miles north) and if (when) I have tube problems I may make a switch back to tubeless.
Reversing the wheels on this tractor just wont work however......but the position they are in is going to be just fine.
Thanks for the info.....gave my tractor a little workout in the woods yesterday....moving some logs and brush.....but the ground is still frozen.....so just gotta wait.:(
/ 790 Tires #15
Question for the 790.... My fronts have the valves on the outside now. If I switch the tires to opposite sides (keeping tread direction the same) will that give a wider stance on my 790??
/ 790 Tires #16
I swapped my fronts on my 790 and it was wider but I moved it back because I suspected it put more strain on my front end, especially when using the FEL and since the front axle is hinged it has to tilt pretty far before it makes a difference.
/ 790 Tires #17
Would you not think that the JD engineers had considered this and designed in enough strength of all the components so that it could handle the stress???
/ 790 Tires #18
It likely won't hurt it. My salesman said it would be OK. I just didn't see that it made a difference. Getting the tires filled, that made a big difference. Now I have 350lbs on my BB and that made a difference. Stills scares me when I get sideways on a slope but the tractor now seems a lot more stable.
/ 790 Tires #19
Is your 790 4wd? I have 11.2 x 24 in the rear but cannot find a 7 x 14 tire for the front with the right rolling circumference to match the gear ratio.
