855 anti freeze overflow leak
   / 855 anti freeze overflow leak #1
gregz
Bronze Member
Hoosier
BX 2350
JD 855 after gettting up to operating temp leaks anti freeze from overflow tube. I replaced cap with oem JD, same issue. I havn;t run tractor long enough to see if major overheat problem. Maybe install new thermostat?
suggestions welcome
thanks in advance
gregz
   / 855 anti freeze overflow leak #2
You can't fill your rad to the neck, the coolant expands when it gets hot and if there's no room in the rad the rad cap spring opens up and it spits out of the overflow. You might just have to much coolant in it.
But check the basics to ensure you have no oil in your coolant and vise versa.
   / 855 anti freeze overflow leak #3
suggestions welcome
thanks in advance
gregz
Is it just too full? Mine runs down about an inch or more from the top.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
