8N 12V Conversion - Points issue
/ 8N 12V Conversion - Points issue #21
if square coil only, then get the 2.5 ohm version and use it with the oem dash resistor
Yes, this dizzy is the sqaure type. What I need to know is where the one wire on the back side of this dizzy goes
/ 8N 12V Conversion - Points issue #22
that post is not on the cap but on the coil itself. that is the wire that comes from the key switch, after passing thru the resistor.
you need to get a master parts catalog and a service manual.. will help you id parts.. make it easier to communicate..e tc. diagnose.. etc..
/ 8N 12V Conversion - Points issue #24
front mounts were 39 into the early 50's
2006 Ford Crown Victoria Sedan (A61569)
2006 Ford Crown...
2012 Mazda 3 Sedan (A61569)
2012 Mazda 3 Sedan...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
UNUSED JCT 72" HYD ANGLE BROOM (A62131)
UNUSED JCT 72" HYD...
2026 Hillcrest Trailer 14166SPT 7 Ton T/A Partial Tilt Trailer (A61569)
2026 Hillcrest...
