8n starting problems
/ 8n starting problems #1
jay1864
new Brunswick canada
1950 8n ford
I have an early 1950 front mount distributor that will not start it run great last week but not a kick now fire at the plugs and it seems to be getting gas even tried a little spray of guick start but no life any ideas?
/ 8n starting problems #2
I'd check the points, clean if burnt. Check and clean the inside of the dist cap. Check for spark from the coil to the dist cap.
/ 8n starting problems #3
/ 8n starting problems #4
to the op. Instead of the wild goose chase.
hotwire the coil.. see if that changes anything.
if no spark still. put a test lamp in line with coil and battery.. crank over. lamp should blink.
if no lamp.. points are not closing ( gap wide? burnt? etc.. - if burnt.. check condensor with ohm meter to verify it is not open.. )
if lamp stays on, points are shorted ( closed up, shorted condensor..e tc. )
post back
if no lamp.. points are not closing ( gap wide? burnt? etc.. - if burnt.. check condensor with hm meter to verify it is not open.. )
post back
Took the weekend off will try the test tomorrow .I do have fire at the plugs but it is white not a good blue.
/ 8n starting problems #6
white and blue are good. orange and red are weak.
/ 8n starting problems #8
if you have good snappy white / blue spark at all plugs that will jump a max gap.. then start looking at fuel delivery, air flow and compression. won't hurt to check timing by book with a straight edge, just because.
/ 8n starting problems #10
good luck , post back
Checked timing cleaned cap points etc got it started but not running well no fire now on number one cylinder tried new plug but no go .I guess I will order new cap roter points and plugs in morning don't think I need new coil because it fires well on three cylinders also tried different plug wire but still no fire on number one got me stumped
/ 8n starting problems #12
before you do all that.. pull the dizzy and rotate it in your hands.. have a battery and test lamp and some gator clip cables. clip battery to dizzy as ground, then clip other side of bat thru test lamp to concave screw.. spin dizzy by hand. observe operation.. bushing clearances.. etc.
/ 8n starting problems #14
looking for play inthe shaft bushings. can cause eratic spark due to changing spark gap
Took distributor out found retaining clip out of place thus breaker plate assembly loose causing shaft end play reassembled and now runs on all four but now have a miss might be bad a bad plug getting closer to running like before will keep working until it does
/ 8n starting problems #16
miss can be a plug or wire or even a hanging valve.
see if you can move the miss to other cyl with plug / wire swap.. or if it stays on 1 cyl.. do a comp test.
Finally running like before disassembled distributor cleaned new gaskets points rotor etc but main problem was retaining clip out of place throwing everything off don't know how it came out butit did had a miss and found a bad plug wire they don't make them like they did before only 1 year old. Thanks for all your input! Now on to my weak hydraulics
/ 8n starting problems #18
Can you still buy stranded copper plug wires?
Jim
/ 8n starting problems #19
Jim
yes.. tsc, napa.. etc.
some spendy places have pre made ones. otherwise 'roll yer own' cut to fit kits are easilly available.
Spring has arrived so on to new project I purchased a backhoe and plan to run it on my ford 2600 but no external hydraulics purchased a block that bolts on under seat for hydraulic supply for quick connects hopefully pump will supply enough oil should I have any big concerns not used to working on hydraulics
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
INTERNATIONAL 490 - 21' DISC HARROW (A63291)
INTERNATIONAL 490...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
