955 - Looking to add a 430 loader
   / 955 - Looking to add a 430 loader #1
jd955sb
Hello - I found myself a nice 430 loader, but my local dealer informed the attachment brackets to make it work are over $1100.00....ouch.:(..I have looked at the parts diagram and the brackets seem pretty basic.
One of my friends is a structural welder and says it would be pretty easy to replicate the brackets if he could get some good pictures and accurate dimesions....sssooooo.....is there anyone with a 420 or 430 loader on their 955/855 who is able to provide me the pics and dimensions?
Thanks in advance!!
   / 955 - Looking to add a 430 loader #2
I have a set of brackets that came with my tractor when i bought it used. It just had a 300x loader installed before I got it but came with the mounts from the old loader (maybe a 420). The tractor is a 2001 4300. I will look for a pic of the mounts and post it. If you can check to see if they will fit your application. You never know who might have what you need!
   / 955 - Looking to add a 430 loader #3
here are some pics of the brackets
Thank you. Looking at JDparts.com, the 4300 uses a different mounting system then my 955 for the 420/430 loaders. Unfortunately, I may have to suck it up and buy atleast one side from JD and use it to make the other. Thanks again...
   / 955 - Looking to add a 430 loader #5
Do you think it is just the mounting flange where it bolts to the tractor? It would be very easy to cut off and weld on a new flange with the correct bolt pattern. You can have these for free if you think they would be of use to you. I am in Ontario but run a car hauler truck into OH, MI, PA, NY quite frequently if that helps. Also know other truck drivers that may be helpfull.:thumbsup:
You might be onto something, i need to add a tube (not bolted on a 955), but I might be able to wrk with that. I live in southern New Hampshire....do your trucking friends come my way?
Thanks again!
Bit the bullet and bought all new JD parts....430 loader works great....very happy with it.
   / 955 - Looking to add a 430 loader #8
It's a strong loader. I'm happy with mine. Moved a lot more than I thought it would
   / 955 - Looking to add a 430 loader #9
I looked at this before I found a 70A for my 955. If I remember right, it was going to cost somewhere around $800. Do you mind sharing what it cost you for the 955/430 brackets? Pics?
I paid approximately $1200 for two main brackets , the front support and hardware. . I ordered everything from greenfarmparts.com , they were great to work with.
I don't have pics currently....59" blower on it now, but will post some when I reinstall the FEL.
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
Sukup 8R Subsoiler (A59814)
Sukup 8R Subsoiler...
