955 - Looking to add a 430 loader
   / 955 - Looking to add a 430 loader #1
jd955sb
Hello - I found myself a nice 430 loader, but my local dealer informed the attachment brackets to make it work are over $1100.00....ouch.:(..I have looked at the parts diagram and the brackets seem pretty basic.
One of my friends is a structural welder and says it would be pretty easy to replicate the brackets if he could get some good pictures and accurate dimesions....sssooooo.....is there anyone with a 420 or 430 loader on their 955/855 who is able to provide me the pics and dimensions?
Thanks in advance!!
   / 955 - Looking to add a 430 loader #2
I have a set of brackets that came with my tractor when i bought it used. It just had a 300x loader installed before I got it but came with the mounts from the old loader (maybe a 420). The tractor is a 2001 4300. I will look for a pic of the mounts and post it. If you can check to see if they will fit your application. You never know who might have what you need!
   / 955 - Looking to add a 430 loader #3
here are some pics of the brackets
Thank you. Looking at JDparts.com, the 4300 uses a different mounting system then my 955 for the 420/430 loaders. Unfortunately, I may have to suck it up and buy atleast one side from JD and use it to make the other. Thanks again...
   / 955 - Looking to add a 430 loader #5
Do you think it is just the mounting flange where it bolts to the tractor? It would be very easy to cut off and weld on a new flange with the correct bolt pattern. You can have these for free if you think they would be of use to you. I am in Ontario but run a car hauler truck into OH, MI, PA, NY quite frequently if that helps. Also know other truck drivers that may be helpfull.:thumbsup:
You might be onto something, i need to add a tube (not bolted on a 955), but I might be able to wrk with that. I live in southern New Hampshire....do your trucking friends come my way?
Thanks again!
Bit the bullet and bought all new JD parts....430 loader works great....very happy with it.
   / 955 - Looking to add a 430 loader #8
It's a strong loader. I'm happy with mine. Moved a lot more than I thought it would
   / 955 - Looking to add a 430 loader #9
I looked at this before I found a 70A for my 955. If I remember right, it was going to cost somewhere around $800. Do you mind sharing what it cost you for the 955/430 brackets? Pics?
I paid approximately $1200 for two main brackets , the front support and hardware. . I ordered everything from greenfarmparts.com , they were great to work with.
I don't have pics currently....59" blower on it now, but will post some when I reinstall the FEL.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
