ThirdMan
Congratulations! Looks like you are getting what you want! (pun intended).
New 2018 Max 26XL 4WD HST with FEL
Mahindra attachments:
5' Heavy Duty Box Blade
5' Standard Duty Landscape Rake
5' Heavy Duty Tilt and Angle Scraper Blade
Rear tires filled w/ WW fluid
Total price out the door: $17k
Will take a week for them to do the set-up and delivery, but I asked for the Operator's manuals now so I can start reading up.
Happy day!
You really should consider a 6' rake and rear blade, heavy duty if possible on both. When a 6 footer is angled at 45*, it's only about 50" wide. Double check to see if you can swing the change. I believe that you'll be much happier in the long run. :thumbsup:
The way you write it sounds like a romance novel<snip>
Happy day!
Get a parts manual and a workshop manual, they may be free online but if you have to pay for them they are well worth it.Still to come:
Either a Harbor Freight or Agr-Supply QA
EA 55" Wicked Root Grapple
Piranha Bar for the bucket
Need to assemble a tractor tool kit. I probably have a lot of the tools already but would like to put them together in a separate tool box.
Assortment of wrenches in most common sizes for tightening bolts (assume this will be metric)
Grease gun (have a Pittsburg Pistol Grip automotive grease gun w/ extension)
Grease (have red grease in the cannister. What other kinds?)
Need to buy a GOOD tire gauge
I use a compressor to fill GT tires now, is that okay? special fitting?
Have a battery tender for the car, anyone use them?
Does anyone wax their tractors?![]()
It is a romance. :cloud9:The way you write it sounds like a romance novel![]()
And Harbor Freight wrenches are pretty good and very inexpensive.
Still to come:
I have the HF quick hitch and it works good but the top hook can be a pain on some implements. I found an alternate top hook that sticks out about 1" further and it solves that problem. There are other threads on the HF top hook issue.
If you're getting a grapple did you get a 3rd function for the loader so you can open and close it?
With all of the rear attachments I'd look into a hydraulic top link. Helps with adjusting the implement angle on the go. How many rear remotes did you get?
Waxing tractors.....I thought about it but haven't actually done it....LOL.
