MANUFACTURER
MODEL John Deere
328
Baler Design
Bale Size
Height x Width, in. (cm) 14x18 (36x46)
Length, in. (cm) 12 to 50 (30.5 to 127)
Maximum Volume, cu. ft. (m3) ---
Dry Bale Weight, lb. (kg) N/A
Pickup
Pickup Width, in. (cm) 74 (187.9)
Tooth Bars/Teeth 4 bars, 104 teeth
Lift Control Crank (hydraulic opt.)
Pickup Diameter, in. (cm) 19.5 (49.5)
Auger
Diameter, in. (cm) 16 (41)
Length, in. (cm) 61 (154.9)
Plunger
Strokes/Minute 80
Stroke Length, in. (cm) 30 (76.2)
Typing Mechanism
No. of Knotters 2
Twine Capacity 4
Twine Type Plastic or sisal
Knot Strength (Minimum Required) ---
Central Lube System Optional
Wire Twisters ---
Wire Ball Capacity N/A
Baler Dimensions
Length w/short tongue, in. (cm) ---
Length w/long tongue, in. (cm) 227 (576.5)
Width, ft.-in. (cm) 108 (274.3)
Height, ft.-in. (cm) 67 (170.2)
Weight, lb. (kg) Empty 2685 (1208)
Tractor Requirements
PTO Speed, rpm 540
Minimum PTO, hp 35 <<<Personally I'd recommend quite a bit more HP with a Thrower and a Hay Wagon is trailing behind with serveral hundred bales in it...
Drive Mechanism
Driveline Equal angle 3 joint category 4
Optional Driveline NA
Pickup Belt
Plunger Gear and shaft
Knotters Gear and shaft
Feeder Forks Gear and shaft
Size of Flywheel, lb. (kg) 227 (103)
Drive Train Protection
PTO Slip clutch & overrunning clutch
Gearbox Disk slip clutch & shear bolt
Pickup Belt slip
Needles Shear bolt/plunger head stop
Knotters Shear bolt
Tires
RH Standard tire size 26x12.0-12, 4 ply
RH Optional tire size ---
LH Standard tire size 11L-14, 6 ply
LH Optional tire size ---
Gauge Wheels 1 optional
Pickup Gauge Wheels Tires Size 16.5x6.50-8
Lights
Work None
Transport lights None
Density Control System
Adjustable Bale Density Mechanical crank
Adjustable Hydraulic Bale Density Optional
Bale Counter ---
Bale Ejector
Available Optional
Bale Chute
Short chute Optional
Long chute Optional
Side bale drop chute Optional
Wagon hitch Optional
