A new NAA project now someday a new loader
   / A new NAA project now someday a new loader #52
how about some details.. some of us use mobile devices and it's like trying to watch and listen to tv on a pocket watch.
post details and get some help. save the vids for the guys with a 22" monitor and souround system.. :)
So you are saying that Ed Abbey was right..." a word is worth a thousand pictures...if it is the right word"
Here are some details.
After the last time it ran, it would immediately leak fuel from the carb after shutting down. I took the carb apart and found that the float was miss adjusted, (at less than 1/4 inch distance from the inverted top of the carb), and the main nozzle was bent. The venturi was bent and had cracks in it (this was described in a different post), and the choke plate was in backwards. I reassembled the carb with new (plastic) venturi, new main nozzle, corrected choke plate, new gaskets and corrected float. For a while I erroneously believed that it was missing jets but turns out it only has the 1 idle jet.
The reassembled carb now holds fuel with out leaking at first. After cranking it for a bit it will drip some fuel out of it. It just won't start.. Its close but just won't catch. I checked the ignition and the rotor is pointing to the number 1 cap terminal with the timing marks on 31 degrees BTDC. I made no other changes between the first running and doing the carb...so I'm a bit stumped. I haven't checked the compression after the new head and gasket but I'm assuming it is good (perhaps bad assumption at this point), With compression, fuel and spark that sucker should run.
   / A new NAA project now someday a new loader #54
i'm away from a manual.. bit i'd check that 31 btdc
The 31 is what my manual says...but there is a lot of debate on the forums. I haven't removed the distributor so assuming it was correct, but as the compression got worse before the previous owner gave up he could have messed with it to try to "regain" some power. Will probably take it up again on monday.
   / A new NAA project now someday a new loader #56
Have you checked the plugs, they may have fouled out when the carb wasn't adjusted correctly.
good Idea I'll do that too
Looks like Varmint1 called it. I put a set of new spark plugs in and it fired right up. Stayed running, checked the timing (looks good) some minor carb adjust. Managed to get a few bucket loads of heavy soaked clay soil moved out of a pile i have. Amazing how traction is reduced with a load in the bucket, got to figure out some rear ballast. Power steering is working and needed a refill after cycling for a bit. Still need to get sheet metal buttoned up but looks likes I'm out of the woods for now. Thanks guys for the appropriate, shove in the right direction at the right time.
   / A new NAA project now someday a new loader #59
Glad to hear its running, simple things can be over looked easily.
Rolled my first tick on the new hour meter...and blew my first hydraulic hose...and fuel tank is leaking, but...it runs pretty good:)
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
CAT Skid Steer (A50322)
CAT Skid Steer...
