A warning for those considering a Gear Drive Kubota L2501
   / A warning for those considering a Gear Drive Kubota L2501 #82
A good salesman will know, but the learning curve is still there. Our local dealer has been run by the same family since the mid 50s, but not long ago their salesman changed careers and the fill in salesman really wasn't up to speed. When a new sales manager was hired, he readily admitted the need to become better acquainted with the various models.
As I have pointed out before you and many of us on here have become the sales people for the industry now. At this point there is virtually no need for tractor sales people anymore. After being here for two years I can say with assurance that many of you know vastly more about tractors then any so called, wanna be sales people at a dealership does.
   / A warning for those considering a Gear Drive Kubota L2501 #84
I want to tell my experience with a Kubota L2501 in case it's useful to anyone considering this tractor, or a L3301. They are wonderful tractors but the buyer should be aware of the following if you're not planning to get a hydrostatic....
First some background: I cut 10 acres of rough land 1-2 times per year. I did this successfully with a John Deere 1023E tractor and 4 foot Frontier RC2048 cutter. The 1023E's ground clearance around the transmission was fairly low, however, and the ride was a bit rough. So I wanted to upgrade this summer. I wanted a Deere 3032E with 5 foot cutter but it ended up being more than I wanted to pay, especially since I am unlikely to ever put that many hours on the tractor. The new Deere 3025E seemed better for my budget, but is not out as of this writing, and in any case my John Deere dealer said it has only 17.4 PTO horsepower and thought that is too little for a 5 foot cutter.
So I talked to Kubota dealers, and they were quite supportive of putting a 5 foot cutter behind a L2501, which has better PTO horsepower than the Deere (and up to 70.2 lb-ft of torque, incidentally, compared to 51.3 for the 3025E and 64.2 for the 3032E; although torque is not probably as important as PTO HP).
I ended up with a Gear Drive Kubota L2501 with 5 foot Land Pride RCR1260 cutter. The gear drive saved maybe $1000 and offered more PTO horsepower (20.5 PTO HP vs 19.0 for the L2501HST). HOWEVER, the gear drive was a big MISTAKE for my situation:
Problem 1: Nonlive PTO. When mowing if you ever need to change a gear or reverse, you must fully depress the clutch pedal, which also shuts off the transmission-driven PTO (and rear cutter). If you are in heavy material and want to slow down or back up, your only choice is to raise the mower and keep going (but not getting the grass cut) or to put the clutch in, bringing the tractor and PTO to a complete stop. (Note that the gear drive L3301 also has nonlive transmission-driven PTO. The L3901 gear drive might have the advantage of a two stage clutch pedal, which can let the PTO keep going as you change gears. However, buyers should check this carefully).
Problem 2: There are only 8 forward gears on the L2501 and they are spaced somewhat widely for mowing. It's hard to find the specs, which are only in the Kubota owner's manual and not online. Here are the details:
Low2 is 1.1 mph (much too slow for mowing except for very heavy conditions)
Low3 is 1.6 mph (very slow for mowing -- much slower than I generally did in my 1023e with a much smaller engine -- but this is the most realistic option for most conditions)
Low4 is 2.8 mph (substantially faster than L3, and generally too fast for mowing for all but the lightest material -- but still may not get a good cut because you're going so fast)
Also: on the L2501 (unlike L3301 as I understand it) there is no shuttle shift, which means that if you want to go from forward to reverse, you have to fully depress the clutch, come to a complete stop, which shuts down the PTO as well, and slowly shift and let your clutch out again. To save the clutch, the PTO and the implement, you really should do all this at fairly low RPM. However, since this action is also how you get the tractor to start moving again, you need some power -- maybe 2000 RPM to get the whole thing to go. Your left leg will really get some strength training!
Anyway, a gear drive L2501, with its transmission-driven PTO and somewhat widely spaced gears, is a little bit like a 1950s type tractor, and is not for everyone! I am sure there is someone out there who loves it, and will promptly tell me I'm just inexperienced. If someone has had a good experience with this tractor, please share.
After nearly 5 hours of frustration, my dealer let me trade up to a L2501HST, which essentially solves the problem. I would not hesitate to recommend the L2501HST to anyone wanting to run 5 foot implements.
I am looking for mowing and snow removal and haul firewood. I am thinking that pressing in the clutch with a blower full of snow will jam the blower up. I also wonder would the tractor go slow enough to run a 6 foot snow blower or will it run out of power in deep snow. Then when you put the clutch in the PTO stops and the blower jams full of snow. Man PTO that is no live PTO without a double clutch could really suck. I wonder does the L2502 have a live PTO
I am looking for that perfect smaller tractor but there is none. Whining hST or no double clutch or live pto for gear tractor. Obvious these engineers never did a days work in their life.
   / A warning for those considering a Gear Drive Kubota L2501 #85
I ran a 6' blower on my previous L3410 HST with 27hp at the pto, and it handled it ok, but barely. I would not want to blow snow with less HP and a manual transmission.
   / A warning for those considering a Gear Drive Kubota L2501 #86
I suppose if it had a creeper gear but at that low hp I think deep heavy snow would have you riding the clutch. Likely if you didn't have a double clutch or independent pto it would be painful. I had the grand l l4740 47 hp using a 6 foot and even then it was sometimes slow going. Guess I will put up with the HST whine. Thanks for getting me to rethink this.
   / A warning for those considering a Gear Drive Kubota L2501 #87
The L2502 gear drive does not have a live pto, I just looked at one and like all the other improvements they made but the pto was deal breaker for me.
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 RoGator RG1100C Sprayer (A53342)
2018 RoGator...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
