acetone increases mileage?
   / acetone increases mileage? #21
I heard on the internet that adding one pint of water per gallon of gas gives better mileage too, but also heard that adding one quart of H2O gives the same mileage? /forums/images/graemlins/crazy.gif
   / acetone increases mileage? #22
I'll try it... need to go to TSC anyway... I've been checking my milage when filling for the last 2-3 months.. 97 firebird 5.7L.. I'm getting 20-21mpg.
   / acetone increases mileage? #23
</font><font color="blue" class="small">( I tried putting them in and was having a heck of time. They kept sticking in the filler tube to the tank /forums/images/graemlins/confused.gif )</font>
<font color="orange"> ********** </font>
Did you grease the filler tube and the magnets first?
   / acetone increases mileage? #24
</font><font color="blue" class="small">( I heard that hanging a plucked, dead chicken from your radio antenna will increase mileage. )</font>
<font color="purple"> ````````````````` </font>
Nope - what that does is increases radio reception.
To get increased mileage you have to attach it to the carb.
   / acetone increases mileage? #25
Any mileage updates?
I haven't had a chance to try it yet. Everytime I'm at the store I forget to pick some up. Will be trying this soon hopefully.
   / acetone increases mileage? #27
Here is my take on the acetone thing: The original website containing the article doesn't lend any credibility to it. Wierd "tree hugging, granola crunching, let's all build perpetual motion machines" sort of stuff. On the other hand, I did some searching and found quite a few people reporting some benefits to using acetone. They weren't associated with the original web site or article and sounded legit. Some were speculating that the improvements seen by some were perhaps the result of the acetone cleaning out a crudded up fuel system rather than any real increase in efficiency burning the fuel. In any event, I read enough positive reports (and no indications of damage) to entice me into trying it.
I put some in my '98 Toyota Tacoma at a ratio of 1000:1 (50mL of acetone in a 50L tank). It's too early for any real results, but on the not quite 1/2 tank I've burned so far it's looking like no real difference.
Now here is the interesting part. I've got an old Farmall M tractor with a front mounted post pounder. This thing is worn out and/or has stuck rings to the point that it normally fouls the plugs withing an hour or two. The normal procedure to get it going whenever I need to use it is to remove all the plugs and sand blast them or scrub them with solvents and a wire brush to clean off all the crusty carbon and still-liquid oil they accumulate. As I said, that buys me an hour or two of running time before it starts dropping cylinders to fouled plugs again.
Our neighbor needed quite a few fence posts put in this weekend, so I decided to try acetone in the Farmall. I put the usual "little bit" of gasoline in the tank (it leaks out, so I don't keep much in it) - maybe 8 or 10 liters. I then dumped in a quantity of acetone best described as "some" /forums/images/graemlins/tongue.gif and proceeded to go put in fence posts.
Somewhat to my surprise, the tractor ran absolutely perfectly for several hours over 3 sessions of post pounding and was still running great when I parked it. I haven't taken the plugs out to have a look, and this test was totally unscientific, but it would seem that there is some cleaning effect to the acetone if nothing else.
Oh yeah, before trying it in my truck, I ran a tank full of good fuel system cleaner through it in an attempt to eliminate the cleaning properties from the equation. If it truly does help the combustion efficiency I should see some mileage improvement. If people's gains are due to the cleaning effect, it shouldn't do anything for my truck. We'll see .....
   / acetone increases mileage? #28
You can make a super high explosive with acetone real easily too. Triacetone Triperoxide (TATP), just need a equimolar concentration of hydrogen peroxide and a little bit of sulfuric acid. It produces an extreme shock wave though, so be really careful.
   / acetone increases mileage? #29
</font><font color="blue" class="small">( I've got an old Farmall M tractor with a front mounted post pounder. This thing is worn out and/or has stuck rings )</font>
if it is stuck rings... run some MMo in the gas an oil.. seems to work well on fords. Also.. remove plugs and add a little mmo to each cyl.. let it set all night with plugs in.. pull plugs int e morning, rotate engine over by hand a few cycles.. add more mmo.. reinstall plugs, next morning, remove plugs, and run the engine over with the starter to clear excess mmo.. reinstall plugs and go. If that don't unstick them... probably no mechanic in a can will.
Soundguy
   / acetone increases mileage? #30
MMo /forums/images/graemlins/confused.gif
My best guess is "Marvel Mystery Oil" (I think I've heard of that before, but I don't know if I've ever seen it around here).
SkyPup: Maybe I should try the mixture you describe. I bet that would unstick the rings! /forums/images/graemlins/grin.gif
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2021 JOHN DEERE 8R250 LOT IDENTIFIER 179 (A53084)
2021 JOHN DEERE...
RIGID TOOLBOX (A52472)
Kawasaki NR (A50324)
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
