acetone increases mileage?
   / acetone increases mileage? #11
Should the magnets be freshly ground or added whole? /forums/images/graemlins/laugh.gif
   / acetone increases mileage? #12
There was a very long running discussion of this at another forum.
I have reservations about any additives, as I believe anything which had such miraculous results would be added before the pumps.
   / acetone increases mileage? #13
Actually if the ketone could reduce the surface tension of the gasoline, it might make for a slightly more efficant burn due to better vaporization. Plus the acetone should really help to clean up the fuel system. It is also 150 octane! /forums/images/graemlins/grin.gif
Sounds like it might be worth a shot, I'm gonna try it next time I fill up that gas hog ranger of mine with 2 ounces per 10 gallons.
**** if it doesn't work, I'm only out like a freaking measly 10¢... less than the price diffrence of 1 gallon of "mid grade"!
   / acetone increases mileage? #14
</font><font color="blue" class="small">( Got it. Sniff it first, then put the rest in the tank, then add the magnets. /forums/images/graemlins/smile.gif )</font>
How many magnet should you put in the tank? I tried putting them in and was having a heck of time. They kept sticking in the filler tube to the tank /forums/images/graemlins/confused.gif
   / acetone increases mileage? #15
<font color="blue"> I am going with the cow magnet strapped to the fuel line
Ben
</font>
Hey Ben,
Please advise, on where to get COW MAGNETS . And can they be put all over the car to help with the gas atomizations? /forums/images/graemlins/grin.gif
On 2nd thought, will also add the Acetone , for good measure. /forums/images/graemlins/shocked.gif
Get your tractors running &
Have a nice day,
Joe /forums/images/graemlins/cool.gif
yeah, I'm going to try it anyway. From what I have read acetone is in a lot of additives anyway and it has a general cleaning effect. It's cheap and as long as you don't spill it when you are putting it in it shouldn't cause any harm. The tripmeter will tell if I keep doing it or not.
   / acetone increases mileage? #17
<font color="blue"> I'm going to try it anyway. From what I have read acetone is in a lot of additives anyway and it has a general cleaning effect. It's cheap and as long as you don't spill it when you are putting it in it shouldn't cause any harm. The tripmeter will tell if I keep doing it or not.
</font>
Hey Tim,
By all means, let us know, how it affects your mileage. I am hopeful, that it will not harm your engine, but at this point, I am thinking, that it is just too risky for me.
I remember, reading about the harmful affects of Methanol, on the carb, and rubber parts, so I am thinking, that something like that may be the result of Acetone, but I really just don't have enough knowledge about what the affects of Acetone would have on the fuel system and the engine.
Best of Luck though,
Have a nice day,
   / acetone increases mileage? #18
Added 9 mL acetone per gallon of gas... or 3 oz per 10 gallons.
Drove for about 6 miles and noticed the engine was running a lil smoother.
Drove for another 30 miles. Noticed the valves were not chattering going up hills.
When I got home, the truck appeared to idle much smoother.
No mileage data yet, but I'll keep using it just cause my engine runs better.
   / acetone increases mileage? #19
I heard that hanging a plucked, dead chicken from your radio antenna will increase mileage.
   / acetone increases mileage? #20
<font color="blue"> I heard that hanging a plucked, dead chicken from your radio antenna will increase mileage.
</font>
Hey Alan,
Well, that would have a perfectly, logical explaination. As the Chicken, most probably, disrupted the air flow, in such a way, to make the vehicle slide through the air with less drag and air disruption, therefore giving the vehicle the ability to have more MPG. /forums/images/graemlins/crazy.gif
Which now, fully explains why, many in the older days, used Coon Tails on their Radio Antenni, and I fully expect for the same reason, for a much smoother running engine and much improved fuel combustion, therefore resulting in improved gasoline mileage. /forums/images/graemlins/crazy.gif
I am hopeful, that the poor people, in this country, do not ireprebly harm their internal combustion engines, by putting a harmful additive into thier gasoline tanks. /forums/images/graemlins/frown.gif Although, I am sure that there will be some or many that will surely do so, with the vehicles, winding up in the salvage yards or on a used car dealers parking lot, to be resold again. /forums/images/graemlins/frown.gif
All jokes aside, anyone reading these threads, should not risk using their own personal vehicle's as an experimentation device to prove or disprove, whether the said additive ACETONE , will improve their engine's performance.
Have a nice day,
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
2024 John Deere 410R Sprayer (A53342)
2024 John Deere...
EZ GO EXPRSS S4 EFI GAS GOLF CART (A51247)
EZ GO EXPRSS S4...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
