petebert
This is the fuel tank I use to fill the tractors.
I'd like to hardline in a filter with water trap like this.
I currently use a portable 12v pump to get the fuel, has a 3/4" rubber line that I drop in through the fill neck. When I'm done with the pump I put it in a plastic tote and put it away. I'd prefer not to buy a permanently attached pump because of how much they cost and I already have a working pump.
There's a 3/8" threaded hole in the bottom of the tank, previous owner gravity fed through that. Here's a picture of the top, the plugged hole is 1/2" and has a pickup tube down to what appears to be about 1" from the bottom of the tank. I'm thinking pipe my filter into that hole and then add a shutoff valve and barbed fitting on the other side of the filter. Whenever I need to use it I put my rubber line over the barbed fitting, done I pull it off and put it away like normal. Any thoughts on this. Any ideas of other ways to do it?
