Adding light switch to NX
/ Adding light switch to NX #1
justman777
Platinum Member
San Antonio, TX
Kioti NX4510 Cab
Want to add a switch on the right column of my NX by removing one of the blanks where all the other light switches are. I ordered a standard rocker switch off Amazon, but it's sloppy in the fitting. Does anyone know of a switch that'll fit that I don't have to pay a dealer $50 for? For clarification, I want to add the switch to the right column where all the other light switches are. On the NX cab model, this is right above the PTO switch/knob.
If I can't find a reasonably priced switch that'll fit, my plan is to make do with some hot glue to the back side. Any other ideas?
Thanks!
/ Adding light switch to NX #2
Take some careful measurements of an existing switch which fits. Surf eBay for one with that configuration and those dimensions. That's how I found a replacement rocker switch for my welder.
/ Adding light switch to NX #3
I made a standard Carling switch work but I shimmed it with part of the blank you pulled out.
Thanks!
I wound up resorting to hot glue. Seems to be holding just fine! Used it for some LEDs on the sides.
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
More info coming soon. (A64557)
More info coming...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
2018 Toro Workman Workamn HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
