additional gauges
   / additional gauges #11
prob safest bet is to pull each sending unit to check threads. on gc2400 oil is simple to get at on left side of engine, temp little more problematic as hoses in way.
I'd check temp sending unit/gauge connections for that temp issue and possibly ohm out temp sending unit to rule out sending unit fail. I don't have figures for ohms on that.
edit: keep in mind if you go aftermarket temp and need a different sending unit you have VERY little room to work with w/o interfering with top rad hose and the bypass hose.
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A57192)
2004 EAGER BEAVER...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
