Advice from the voice of EXPERIENCE !!
   / Advice from the voice of EXPERIENCE !! #61
When launching your boat for the 3rd time & learning from lessons 1&2..
If I may ad a lesson 4; Don't sit on the bench by the boat ramp drinking beer and laughing at new boat owners doing silly things. They are already cussing up a storm and mad enough to cuss at the one they love the most. Some of them may want to "talk" to you.
   / Advice from the voice of EXPERIENCE !! #62
Never use a flame from a match to see in the dark. There may be fumes that you are not aware of, and NEVER inspect a drum or tank with a match.
Never drive behind or near a cement truck, flatbed trailer, or dump truck, they always have loose rocks that fall off and you’ll lose a windshield.
Never let any passenger in your vehicle put their feet on the dash, in an accident their knees with come back into their head from the air bag.
When hauling and loading equipment, trailers math is your friend. Check the weights and limits of all chains, tie down straps, trailers, trailer hitches, hitch balls etc. Always pull forward get out and recheck everything TWICE. I had a hitch ball sheer off at the base of the ball leaving my trailer dangling in the air. Never EVER buy Chinese hitches, clevis shackles, etc. no matter what they say the weight load limits are. Spend the extra money on USA equipment.
Understand that the ANGLE of your rigging can reduce safe loads up to 75%
Understand that FORCE ( Impact sudden stop ) (Shock load ) that can be up to 20 to 50 times the weight of anything you are securing. If you are hauling a 5,000 tractor the weight can exceed your chain or strap loads in a panic stop.
https://energy.gov/sites/prod/files/2014/01/f6/HoistingRigging_Fundamentals.pdf
When using gasoline understand that the fumes can travel very far from you and the can and will find an ignition source.
Never get off a piece of equipment while it is running.
Always dispose of rags used for staining wood in a bucket of water, they will spontaneously combust.
When pulling someone out of the mud or snow, do not use the run and snap method as that will over stress the limits of any two strap by three fold and cause the strap to break with a violent snap motion back at your vehicle. This goes along with knowing the linits of winching people and having the cable break sending a missile back at you and your windshield.
Always carry a fresh set of batteries along with any flashlight you carry, chances are when you need the light the batteries will be shot.
After any fluid changes even though you swear you checked all the fluids and plugs – do it once more before you start the equipment.
While climbing on equipment always have three points of contact and MOVE SLOW.
As silly as you think you look, wear safety gear, gloves, eye protection, fall protection. You only get one set of everything and if you lose it it’s gone forever.
   / Advice from the voice of EXPERIENCE !! #63
When shooting a r****, and using your hood as a rest, remember the scope is higher than the barrel.
   / Advice from the voice of EXPERIENCE !! #64
Your "driving behind trucks" advice is right on. I can testify to two incidents personally. I knew better, but was boxed in and couldn't get around the offending truck both times. One, lost windshield and fog light, two, lost tire, rim and running board when a piece of sheet steel flew off a flatbed. Wife was nearly impaled by a flying exhaust stack. I witnessed a small pickup demolished by a spare that came off a truck.
I got a new one. From my sister last Saturday night.
Never assume the deer that just ran across the road in front of you is smart enough to not try to recross the road at the same time you arrive at the spot.
   / Advice from the voice of EXPERIENCE !! #66
How long was the crease left in the hood?
   / Advice from the voice of EXPERIENCE !! #67
Don't attempt to pass a vehicle in the right lane by using the left passing lane when there is a snow plow truck plowing the inside (center) shoulder on a divided highway.
Had a friend who lost his head over that ... literally ...
(instant decapitation via his shoulder belt when the plow truck peeled the entire driver's side of his van off)
   / Advice from the voice of EXPERIENCE !! #68
If you want to, spend many thousands of dollars to get your lawn looking something like a two acre pool table.
By all means, buy yourself a brand new tractor with a nice backhoe on the back.
You can even park that tractor on your lawn when you go for lunch and it is a good idea to lower the backhoe bucket teeth down on the grass to relieve the hydraulic pressure.
But after lunch, when you hop back on the tractor, DO NOT drive the tractor the full length of your lawn without lifting up the backhoe bucket.
It was a neighbour who demonstrated this valuable lesson. At least he was smart enough to get rid of the tractor before he caused even worse damage. I think his wife might have helped him make that decision!
   / Advice from the voice of EXPERIENCE !! #69
Dave's ancilliary rule: Always assume that the deer following the one that ran in front of you is determined to run into the side of your truck.
   / Advice from the voice of EXPERIENCE !! #70
It went in and out the other side. Fortunately, it was dad who did it.
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2000 Cat 988F (Hrs. 34596) - SN 2ZR01897 - selling offsite : Salem, VA (A60429)
2000 Cat 988F...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
