Advice on buying an upgrade tractor
   / Advice on buying an upgrade tractor #21
Hey thanks guess I replayed at the wrong place
   / Advice on buying an upgrade tractor #22
I would be leaning toward the M7040 if you can find one and the M7060 with a 12/12 hydro shuttle. bigbull338 upgraded to a 7040 and foremanEtexas went from the 5040 to 7040 and I believe they are doing pretty much what you plan. I have an M8540 I really like, but you won't need to go bigger than the M70 I don't think.
TripleR is correct and I would have saved some money making the right choice the first time. I have two 7040's both around 900hrs and have been trouble free. I work them pretty hard too. Last year I baled around 600 of the 4x5s and maintain now around 800acres and pull a 12&15ft batwing.
   / Advice on buying an upgrade tractor #23
Thanks a lot, just talked to Steve (barrows) a few minutes ago, re figuring the cash price, I am mixed up, our NH jumps about 8 thousand and I just don't see that although it is a heavier tractor
I priced the 9960 in Sept. '14. I seem to remember $52,900 @ 0% for 60 months. Equipped with cab, FEL, 12 speed, 3rd function, 3 rear remotes, 540/1000 PTO, radial tires w/ cast rear wheels, air ride seat, etc.
The NH T4.95 runs about the same $ similarly equipped. The NH standard alternator is 120 amp, Kubota will hit you with a $500 dollar up charge for a 100 amp alternator and you will need the bigger alternator.
If interested in a NH, I can send a pm with dealer info.
One of my main dislikes with the Kubota is the exhaust stack is not corner post mounted - right in the line of sight. I don't know why they designed it that way since the 40 series tractors were corner mounted. Based on the Nebraska Test Lab, the NH T4.95 weighs over 8400# and the 9960 at 6700#.
   / Advice on buying an upgrade tractor #24
Check out the LS tractors...incredible bang for the buck. I'm LOVING the blue and if I was going to get another that would be it. Happy with the yanmar till that day comes though.
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2014 Volkswagen Diesel Passat Sedan (A56859)
2014 Volkswagen...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
