Advice regarding Brush Hog for our compact tractor
   / Advice regarding Brush Hog for our compact tractor #1
George_G
We recently purchased a Kubota tractor (BX2200), with a Class I 3-point hitch. Can anyone recommend a Brush Hog that will fit this tractor?
   / Advice regarding Brush Hog for our compact tractor #2
What HP do you have? You'll probably do best with a 4' rotary cutter, Howse is pretty reasonably priced. You could probably get away with a 5' if you need the extra foot.
I bought my Howse 5' a couple of years ago, used. It has been very reliable, even though it was abused in a former life and the deck has been patched up because of it, a few times.
Most rotary cutters are built like Fort Knox though.
Chris
   / Advice regarding Brush Hog for our compact tractor #3
My 24hp Deere uses a BushHog Squealer SQ600, a five foot, light duty model. I've been happy with it. The BushHog vendor had several different models and sizes in their lot. I trailered my tractor to their store and hooked up a couple different sizes and weights before making a decision. I would recommend that to you, if you can.
Otherwise, I agree with Torquin. My tractor is slightly larger than yours, and a 5'er is about as much as it can handle. A 4'er is probably a safe bet.
OkieG
   / Advice regarding Brush Hog for our compact tractor #4
You don't want anything bigger than a 48" on the back of your BX in my opinion. The BX is too small to handle the weight and I doubt the 3PH will handle the bigger cutter easily either.
If you don't have a loader, you may find the front wheels of the BX lifting when you try to lift a 5' cutter, if you can attach it.
I know with my BX, without a loader, the front wheels have left the ground when I was backing up and stopped quickly, with only a 6' landscape rake on the back (that does not weigh much).
Kubota recommends a 48" rotary cutter for my B2910. I use a 5' on it, but would never even consider trying to hook that 5' rotarry cutter to my BX2200.
I would go with a 48" max for a Kubota BX, and might even choose a 42" unit (but probably not). /forums/images/graemlins/smile.gif
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
White Metal Roof Panels (A55758)
White Metal Roof...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
light tower (A56857)
