I hadn't noticed he only had 3 post. I'm not going to call foul yet, but it certainly does reduce his creditably.How come nobody is calling foul here? I assume you guys know the OP and consider him credible? My screen shows he has only 4 posts. Whats crazy is; I posted a serious question and started a thread about starting engine with PTO engaged and in that thread someone accused me of "trying to stir things up". It aint adding up in my world.
Let's hear back from the OP and get an answer to where this dealer is located. There is no info as to where the OP is except Ohio, too.
If this is a scam, I don't know why people bother with doing things like it.... time will tell.:confused3:
Except that TBN rules prohibit publicly naming the dealer in cases such as this as it almost always turns into dealer bashing and could open the OP up to a lawsuit for slander...Agreed, lets hear back from the OP. I tell you what we can do, if the OP responds back with credible and accurate info on this dealer, we could all call this dealer and apply some heat if it is truly legit. OP, give us the name of this dealer and we will help you out.
Says the guy with 29 post who admits to being bitter about how he was treated in the past and now wants to know why someone else isn't being treated poorly too.
Seems like things "add up" fairly well.
Aaron Z
Years ago I used to own and operate an auto transmission shop. Every once in a while a customer would ask us to "tow out" a vehicle from another shop and fix it because the original shop couldn't/wouldn't.
We typically refused to do this because it was common for the original shop to sabatoge the tranny or "lose" expensive parts. I knew several mechanics that faced this problem and warned me when I opened my shop. The original shop always swore that everything was there when it left. The worst was when they would drill a small hole between 2 passages in the valve body. The transmission would never work properly and the second dealer/mechanic was stuck with a large and expensive problem.
Beware of vindictive dealer who faces a large loss.
I'm not inclined to vet a poster or thread before responding and don't see it as a Kioti thing, there is a Kubota dealer I won't go near as well as JD, AGCO and yes Kioti, but I own Kubota, JD, MF and my brothr loves his Kioti. It's not the product I see as problematic.
