Ag tires vs R4
   / Ag tires vs R4 #51
Scientific data (aka my experience:)) has shown that R4s are great for every job unless it involves mud. Mud and R4s will make a preacher cuss.
I can confirm that!
A week ago I was digging a ditch to lay in some 18" drain pipe. The ditch was about 300' long. With my tractor, I can dig about 3-1/2' deep with the bucket pointed straight down.
Anyway, there were some wet areas that turned to mud very quickly. I was operating on level ground and all of the dirt was long established hard-pack... so I wasn't getting in deep mud, just surface. Well, I was sliding a lot. Tight turns -- which I was doing a lot -- would not have been possible without 4wd. My R4s could have been racing slicks and I would not have known the difference.
   / Ag tires vs R4 #52
I can confirm that!
Hope you used your split brakes as well. They usually make a notable improvement in turning in 4wd when its slick.
larry
   / Ag tires vs R4 #53
I found my notes buried in a pile. Here's my numbers on the 3320 weight.
Tractor 2900# + 300 CX 850# + bucket 300# + ballast 850# = 4900# Field Ready (less implement)
I just found the wieght on the 70 loader to be 646 lbs...but I don't know if that includes the bucket. So....2100 tractor +646 loader +400 ballast = 3146 # including bucket??
I had the small size R1's on the 790 and the big R4's on the 3320 thus a big difference in ballast.
I rest my case. ;)
I'd guess you'd add the bucket weight (on the 790) for comparison...especially if they're both 61" buckets (I'd guess the 790 had a 54" bucket though).
Anyway, close enough for government work!
   / Ag tires vs R4 #54
Here are the load figures for my front R1w's per tire.
At 35 psi my front end is rated at over 9,000 llbs.
And these are R1 pattern with R4 sidewalls; Michellin XM27's
25 mph 20 mph 05 mph PSI
1,710 lbs 1,830 lbs 2,500 lbs 14 psi
1,940 lbs 2,070 lbs 2,790 lbs 17 psi
2,160 lbs 2,330 lbs 3,080 lbs 20 psi
2,390 lbs 2,570 lbs 3,370 lbs 23 psi
2,620 lbs 2,810 lbs 3,660 lbs 26 psi
2,850 lbs 3,050 lbs 3,950 lbs 29 psi
3,080 lbs 3,310 lbs 4,230 lbs 32 psi
3,310 lbs 3,550 lbs 4,530 lbs 35 psi
I do not see much worry for FEL loads.
   / Ag tires vs R4 #55
R 1-R4 tires bought a extra set of wheels on ebay 187.00 all 4 shipped to the door went to goodyear and bought a set of R1 tires for my 2305 john deere 300.00 all 4 so now I am ready for snow lawn or field . simple.
   / Ag tires vs R4 #56
There are a few more places where R4's a real bad. On tilled or "loose" soil they are extremely poor, delivering far less traction than R1's (this is why you dont see them on farm tractors). Snow may already have been mentioned, but that deficiency is easily overcome by the addition of chains. On a 4wd tractor with loaded R1's, chains are rarely necessary for operation on snow. Using chains on R4's, as a traction booster in mud or tilled ground, sounds easy, but is actually very inpractical compared with just gettig the right tires (R1's). On a 40 hp tractor, R1's should also save you about $400 on your purchase price compared to R4's.
   / Ag tires vs R4 #57
I think if you tried to go in a farmers field with a R4 tyre here you'd probably get shot, they are very damaging to crop land .
   / Ag tires vs R4 #58
I have searched this thread and wonder what the definition of "mud " or "snow" is. I have R4's and plow/blow no problem in the snow so far and that was with 20" plus storms and walking through 3' to 4' drifts at times. They did spin from time to time but did not hinder me from a practical standpoint. When the soil gets soft enough for their to be a difference for "mud" I would believe that R1's would make a difference but that is if I were doing "only" field implement work. When I do brush out and clear stumps and debris the R4's are great. When I do loader work and backhoe work the R4's do great. When I blow/plow snow the R4's are adequate, not great. When I seed/fertilize/aerate/lime the lawn they once again are adequate and would only be better if I had turfs. R1's would tear it up. If it is "muddy" enough for the R4's to ball up and not work well then I would not be going out. If all I were doing as I mention above is the field work then hands down the R1's in "mud" would be the way to go. But when the soil is wet or soft but not necessarily "muddy" they are adequate. It's kind of like the big trucks with the huge monster or extra large lugged tires. Unless you are in bottomless "mud" all the time they are ridiculous. R4's sell and are used for many for good reason. They work adequately, not great, for most, applications. To each his own when figuring out what to go with. I have considered chains for R4's but have yet find that I needed them, not that will not be the case at some point.
   / Ag tires vs R4 #59
Lol this is funny. Out here if you dont float on the soggy ground you aren't going anywhere. R1 Tires here will sink in and the whole tractor will be stuck. I till, brushhog, and do boxblade work plus FEL stuff. My place(preschool business) would look like some kind of mud pit if I used R1.
Part of the problem is the tight turning radius of the Mahindra. You dont dare turn very sharp in 4wheel even with R4.
I have even moved snow with it. I didnt chain up but if I was doing a lot of snow I probably would chain the front tires with a lightweight chain. I didnt notice a lot of difference compared to my dads kubota with the ag tires. but then my mahindra is a bit bigger then his b1700.
Either one will have trouble in snow at 30 to 33 degrees. But colder it isnt such a problem.
If you like plowing in mud and your mud is only a few inches thick then ag tires will be your best bet. Personally I dont work the soil with anything when the ground is saturated damp. Just seems to make a big mess I cant do anything with.
   / Ag tires vs R4 #60
I would expect AT LEAST a warning shot if I took a tractor of any sort on someone else's crop land (-:
I think the O/P was NOT considering growing row crops, but more general utility applications.
CUTS typically don't have wheel track spacing that is adjustable to suit row crops ANYWAY, so this is hardly an issue.
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
1995 Rinker Captiva 190 (A55315)
1995 Rinker...
