Ahp Tig welder 200x
   / Ahp Tig welder 200x
Yeah, no problem. $1800 to weld cans. Think I'll just give up drinking Dr Pepper. Seriously, if you need something like that it would likely be for making pump flanges and such.
I'm great at spending others hard earned $$$
I was kidding around.
Sent from my iPhone 5s 64Gb using TractorByNet
   / Ahp Tig welder 200x #82
In the same vein, didja set up a bend test for those cans? :D
   / Ahp Tig welder 200x #83
Bend test? I haven't welded two together yet if that's what you mean. I have no doubt the machine can do it and do so quite well. If, with my extremely limited experience I was able to puddle and fill on the can without punching through was the main reason for doing this.
   / Ahp Tig welder 200x #84
Sent from my iPhone 5s 64Gb using TractorByNet[/QUOTE
I think we're all great at that. Yes, of course I knew you were joshing.
   / Ahp Tig welder 200x #85
   / Ahp Tig welder 200x #86
   / Ahp Tig welder 200x #87
Check out videos on youtube from "weldingtipsandtricks" or
check out Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Best arc shots of tig welding.
Love those Pyrex cups. Couldn't get the vids to play, but that looks like the Lincoln guy- am I right? I've seen some of his videos and he is just impossibly good. Where's the best place to get Pyrex cups? If it looks like I'm going to be doing mostly lightweight stuff I may get the CK-9 kit from Mr. Tig. May just do it anyway and save the CK -17 for heavier work.
   / Ahp Tig welder 200x #88
Never used pyrex cups. The regular ones are more durable. I will recommend getting a gas lens though. More tungsten stickout will help you see what you are doing better than a transparent cup IMHO.
The guy who calls himself Mr. TIG isn't very good. You should see how the members of the welding web forum rip on his work. In particular his video on building a smoker.
http://www.youtube.com/watch?v=Nua2SF-oqSM&feature=youtube_gdata_player
Look at 12:35 see all the sparks. Not properly prepped for TIG welding.
   / Ahp Tig welder 200x #89
That seems like an expensive way to make a smoker. He must be in bed with the Argon companies. I will say I got a good tip from him and after trying it both ways he is right. On dirty aluminum the wire brush just makes it worse. Kenny at the shop said the same thing.
   / Ahp Tig welder 200x #90
Ok, as suggested by CNC-Dan, I got a stubby gas lens kit from HTP. All I can say is the torch is now infinitely better. Even my fillet welds look pretty good. Now Kenny at the shop says he doesn't use one, but does own them. Obvious from his welds he doesn't need it. But for me the gas lens is like night and day different. No idea why. I'll post some weld pics when it cools off here, the shop was about 105 in there today. It may be just me, but if you're new to TIG get a gas lens.
John Deere 4600 (A53317)
John Deere 4600...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
Toro 880 Procore (A55758)
Toro 880 Procore...
