RiverV
Bronze Member
I believe that part number (K2561-82170) may come back listed as a Washer, Support. It's a rectangular washer with two holes that mounts on each side of the air cleaner band. My dealer told me that this was the first attempt at fixing the problem. He said early BX's did not have the washers but later ones had them factory installed. Mine had the washers and the band still broke.
There is a heavy duty kit to replace everything. That is what my dealer got and sent to me. I don't have a scanner so I'll type out what my kit consisted of.
Top of the instruction sheet said:
Bracket, Kit (Air Cleaner) K2561-98211 for Kubota Tractor BX2200D
There was an orange label on the box which read:
Kubota Manufacturing of America and had the following numbers on it:
K2561-98210
KMA Part K2561-98211
Kit consisted of the following:
K2561-8218-0 Stay (Air Cleaner,1)
K2561-8219-0 Stay (Air Cleaner,2)
15371-1125-2 Band, Air Cleaner
PA505-7316-0 Collar
15371-1187-0 Cushion
01123-50820 Bolt, SEMS
01123-50870 Bolt, SEMS
02751-50080 Nut, Flange
K2561-9822-0 Installation, Manual
Probably more information than you wanted to know. Hope this helps someone out.... Dave.
K2561-98210
PA505-7316-0 Collar
