Air Compressor Recall
   / Air Compressor Recall #1
duanet
Near Ithaca, NY
JD4100 HST
There's a safety recall on 485,000 Ingersoll-Rand air compressors, so it's likely some of you TBNers have one... I do. I've pasted below the text from Safety Alert which will link you to IR for information.
Duane
SafetyAlerts
February 26, 2002
Ingersoll-Rand Has Recalled Portable Air Compressors
Woodcliff Lake, NJ (SafetyAlerts) -Ingersoll-Rand Company has recalled about 458,000 portable air compressors sold between 1983 and 1991. Internal corrosion to the inner wall of the air receiver tank can cause the air tank to unexpectedly rupture allowing pressurized air to suddenly and forcefully escape, posing risk of injury to consumers.
Ingersoll-Rand has received 11 reports of sudden tank failure in these portable air compressors. No injuries have been reported.
The recalled portable compressors have single-phase electric motors up to 3hp or gasoline engines up to 8hp with tank sizes up to 30 gallons. The compressors were marketed under various brand names, including Ajax, Charge Air Pro, Energair, Guardian Power, MacTool, Power Force, Rallye, Rand 4000, and Steel Driver. The compressors have serial numbers beginning with the prefix "C" or "DC". The model numbers begin with the following prefixes - 1B, 1D, 1E, 1I, 2B, 2D, 2E, 3B, 3D, 3E, 4B, 4E, 5E, 5G, 15E, 23HP, 75, 75E, 250E, AB, AIR, AJ, C, CAP, CB, CL, CO, CP, CR, CS, CT, EA, GC, GP, HP, HPC, IR, IRC, LTD, MT, OI, PF, RA, RL, RP, RY, SC, SDS, SE, THP, and WB. Model and serial numbers are located on a plate or sticker attached to the outside housing of the air compressor. On some oil-less models, the model and serial numbers are affixed to an internal floor baffle beneath a removable plastic cabinet.
Hardware and construction supply stores nationwide sold the air compressors from 1983 through 1991 for between $150 and $400.
Air compressor receiver tanks do not have an infinite life. Tank life is dependent upon several factors, some of which include operating conditions, ambient conditions, proper installations, field modifications, and the level of maintenance. The exact effect of these factors on air receiver life is difficult to predict. Due to the current age of these products, Ingersoll-Rand is voluntarily undertaking this action to take these products out of service.
Consumers should stop using the air compressors immediately and contact Ingersoll-Rand for instructions on returning the compressor, freight paid. Consumers will have the option of being sent a check for $100.00 or receiving a $200.00 credit towards the purchase of a new DD2T2 air compressor. For more information, consumers can contact Ingersoll-Rand at (877) 552-2952 between 8 a.m. and 5 p.m. ET Monday through Friday or visit the firm's web site at <A target="_blank" HREF=http://www.air.ingersoll-rand.com>http://www.air.ingersoll-rand.com</A>.
   / Air Compressor Recall #2
I had a neighbor farmer who in the summer of 2000 reached under his tank to open the valve and drain any condensate out, and the tank exploded as he reached - blowing his hand apart and giving his face a lift (black and blue with some cuts). Several months and a lot of corrective surgery went by to get his hand back to a semblence of what it once was. I don't know what brand of compressor it was, but it sounds like they all might be a ticking bomb - getting thinner in the walls as time passes. Short of some technique to measure wall thickess for thin spots, or internal rust, anyone know of a good way to monitor or measure the tanks condition.
   / Air Compressor Recall #3
Beenthere:
Vessel inspections.
There are non destructive tests. Ultrasonic and x-ray are several. Depending on the size of the tank it may be cheaper to replace it that have it tested.
You could also do a presure test at about 1.5 times the normal working pressure but do this only with water in case of failure. I would not recomend this method.
There should be a State Deity that regulates the testing of all pressure vessels over a certain size and pressure. They would be able to give proper advice even if your tank does not fall into regulations.
Egon
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
UNUSED FUTURE 100YG PIPE GRIPPING MACHINE (A60432)
UNUSED FUTURE...
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
2378 (A60432)
2378 (A60432)
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
