DieselPower
Elite Member
- Joined
- Sep 30, 2006
- Messages
- 2,756
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
saparks10 said:There of course is no pure sulfur additive. If you check the back of many fuel additives you will see a certain PPM of sulfur in the additive. You will not see sulfur alone as an additive, that would be ignorant. Listen guys all i'm trying to say is that sulfur is used in additives to enhance lubricity. Regardless of what the reason is, ULSD has less lubricity. So without an adequate fuel additive there is more wear taking place within older engines. The companies that are refining the ULSD and stripping it of its lubricity are blending additives with the fuel before it is distributed, but the additive package does not compare to the initial lubricity of the fuel before the PPM of sulfur was decreased. It doesnt matter whos additive you use, but you should use one, even if its just to clean the engine and fuel components.
Never said that newer formulations of fuel didn't have lower lubricity, they do. It's just what is lowering the lubricity.
jsborn said:Did anyone ever answer the original question and help us stop or prevent Algae in small storage drums or tanks? I can't keep it topped off and I don't want Algae so what should I do?
Yes, it was answered somewhere back there. The product you want to prevent growth or kill off existing microbial growth is a biocide.
One of the best way's to prevent growth in the first place is to ensure you keep your tanks topped off. The less air in the tank the less moisture laden air that will get in, the less condensation you will get which will reduce the amount of water in your tanks. The bacteria grow in the boundary layer between the water and fuel. Take the water away and you remove part of their home.
