Alien Invasion - I want my pond back !
   / Alien Invasion - I want my pond back ! #21
OP mentioned some kind of EU scheme to reclaim the pond. I wonder if the invaders were EU bureaucrats.
The Pipe
A trailer load of pipe was gratefully received on loan in the summer of 2006 and I set to laying it out on the grass to see what I had taken on. The black, 2" diameter MDPE turned out to be in a few more sections than I first thought, each no more than 50 yards in length. In some places it also had nicks and gashes where it had been caught by a mower cutting hay.
Most of it was easy enough to uncoil and move around, although a couple of lengths were really heavy. Perhaps there was still water inside ? I dragged these onto the slope, expecting, or at least hoping, for water to pour out. Nope, it was something more solid. The pipe had previously been used for emptying waste water from a cattle yard, so chances were the contents were probably something that had previously come out of the rear end of a cow. Maybe that's why it had been left in a field. By lifting the pipe by hand a few inches off the ground, I could feel where the blockages where. In the middle on both lengths.
With nothing much to loose I set to connecting the first bunged up pipe to a water pump. The pump ran quite happily at first, no doubt as the water was initially only compressing air. Then the Honda engine started to hunt harder as the load increased. This went on for a minute or two with nothing moving, but the pump wasn't giving up and neither was I. A bit of lifting and dropping of the pipe had something moving and I could tell from the sound and increasing weight that the Honda was winning ground. The engine changed note and with a final whoosh out popped the poop. Whole piles of it. A few minutes later and the water was running clear. :)
The second blocked length must have realised that it wasn't worth putting up any resistance after what had just happened to the other one and gave up it's smelly contents without much fuss at all.
Now all I had to do was join and repair the pipes. 2" compression couplers are not cheap and anyway, were against the rules, as by then I was determined to try and empty the pond for free. I had read a little about butt fusion weld joints and was tempted to have a go at a home made version, although time was not on my side. Then I remembered dismantling an old storage tank, which had a short length of plastic pipe on the outlet. At the time I put it to one side, as it was another one of those things that was "too good to throw away", though I had no idea at the time what it could be used for. As luck would have it, the internal diameter of the hoarded outlet pipe was the same size as the external diameter of the 2" pipe. A perfect sleeve. :dance1:
With the permission of the pipe's owner I set to cutting out the damaged sections. A sleeve was made for each end, pushing it half way on one pipe before butting the ends together and melting the sleeve in place with a blowtorch to make one long run of pipe. A quick test with the water pump on the end showed up a couple of poor joints that wept a little, but easy enough to seal.
For good measure I taped over the whole joint to try and keep air from entering the pipe as siphons work below atmospheric pressure. Siphons suck - potentially, in a good way ;)
   / Alien Invasion - I want my pond back ! #24
Most likely with a story 10 years in the making, this should be pretty epic.
   / Alien Invasion - I want my pond back ! #25
Hmmm. I guess the poop in the pipe was not your invader.
   / Alien Invasion - I want my pond back ! #26
Eric, you are making a profit to this point in the saga--free fertilizer. :D
   / Alien Invasion - I want my pond back ! #27
Following
   / Alien Invasion - I want my pond back ! #28
Is it a pipe dream or a dream pipe?? Only time will tell!!:listen:
   / Alien Invasion - I want my pond back ! #29
Free BS, good deal.
The filter
With all the pipe in place I had a good feeling that the siphon was going to work. Only question in my mind was how long would it run before getting clogged. I have used short lengths of tubing many times to siphon off small tanks and sooner or later, if there are leaves at the bottom of the tank, they get sucked in and bring everything to a stop. Not too bad when you are there, but this one was going to have to run day and night unattended if it was to empty in time. The pond had a full summer of weed growth, providing lots of potential for constant blockages. It was going to need a good filter on the end.
I reckoned that a fine strainer on the suction end would clog too quickly. It would be better to accept that small stuff getting in would be acceptable, as long as there was with plenty of flow, then the inside of the pipe would be self cleaning. When I sleeved the pipe joints, I had been as careful as possible to keep the inside of the pipe smooth, chamfering the ends before butting them up, so hopefully there was nothing for weed to catch on once it was in the pipe.
The wonders of the internet told me a lot about siphons. One potential problem is that a whirlpool can form when a suction pipe is running just below the surface, in the same way as when water empties out of a bath. This allows air to be sucked down and into into the pipe. Air is the siphons worst enemy, as it can accumulate at the highest point and bring everything to a halt. The faster the water flows, the further down the whirlpool effect goes.
It seems there are 2 ways to overcome this :-
1) Slow the flow down. Not a good idea for me. Reduce the gallons per minute and the pool wouldn't be empty by September.
2) Increase the area of the last bit of pipe at the suction end. This doesn't alter the gpm going through the pipe, but does slow down the water at the point of entry. For example, fitting a "T" section on the end of the pipe would double the area and half the velocity. pipe ends.jpeg
I made up what I thought was a simple alternative - drill holes in the sides. With a sharp drill bit I drilled lots of 10mm holes in the last 10" or so of the pipe to give a similar area-increasing effect and crossed my fingers that it would work too.
A sump had been dug out at the edge of the pond, with chicken netting stretched across the mouth of the sump as the primary filter. The filter box was dropped into the sump and weighted down to the bottom.
All set to go, except for one bit of detail. How do you prime a siphon that's over 200 yards in length ?
   / Alien Invasion - I want my pond back ! #31
A vacuum pump?
Connect the outlet end of pipe to the air intake on your tractor. Start your engine. :laughing:
   / Alien Invasion - I want my pond back ! #33
shop vac.
   / Alien Invasion - I want my pond back ! #34
Fill the pipe with water by pumping water into the outlet end.
   / Alien Invasion - I want my pond back ! #35
Suck.
   / Alien Invasion - I want my pond back ! #37
Is this thread like one of those books where you choose what happens next? If you choose 'suck on the pipe', go to post #47. If you choose 'use a pump', go to post #43.
This is a rather enjoyable thread...I'm on the edge of my keyboard!
   / Alien Invasion - I want my pond back ! #38
Could you plug the end in the pond and fill the other end with a garden hose then remove the plug and hose at the same time? A vacuum pump would work. A shop vac couldn't pull the water high enough.
   / Alien Invasion - I want my pond back ! #39
That's a good idea, but I don't think you would have to plug the end in the pond. You would want to leave it open to let the water coming in from the hose force the air out. Then, remove the water hose and voila!
It's still fun to speculate what the OP did, even though this was done 6-8 years ago. :)
   / Alien Invasion - I want my pond back ! #40
Put a valve on each end. Lay the pipe on an incline and pump it full of water, letting all air escape. Close the valves. Put the ends in their respective places and open the valves.
I thot you had to be done by 2006.
John Deere S350 (A60462)
John Deere S350...
MINI EXCAVATOR ATTACHMENT SET (A60430)
MINI EXCAVATOR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2391 (A60432)
2391 (A60432)
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
