Almost ready to sign . .is the 2320 the right choice?
   / Almost ready to sign . .is the 2320 the right choice? #11
Sounds like the 2320 should/will serve you well... The main advantages of the 2320 are the extra height, 3 pt position control and a little better hydraulic flow (AND a larger backhoe down the road ;)). There are other advantages.... but those seem to be the main ones. IF you're truley wanting a more capable machine than the 2305 then I would strongly recommend taking a good look a the 2520 instead of the 2320. If you're simply wanting the above things I mentioned... then the 2320 should serve you well over the 2305.
I went from a 2210 to a 2520 and back to a 2305... :) Have fun... and be sure you think of ALL your future uses... Very few owners ever buy a tractor to big.... but many later regret buying a bit to small.:eek:
Thanks for the insights. It seems you agree to some extent that I will get a few benefits in the 2320 over the 2305 . .and can probably get the jobs done I need . .maybe a little slower. It's easy to make the jumps in price . .as you said . . and justify them . . but I have to keep a grip on my reality. I've already pushed my envelope past my initial 2305 estimates . .so I should quit at the 2320.
I'm sure I'd be happier with a 2520 . .but probably don't NEED one. If I progess in the world of tractors and uses . . who knows . . I'll probably be looking at the 3xxx's in 2 years . .
Thanks for the help.
   / Almost ready to sign . .is the 2320 the right choice? #13
There you go.... sounds like you've got it figured out. Be sure you do get a test drive in (on your property if possible) just to be sure. The 2320 will be a sweet machine for you.... AND be sure you post lots of pics ;) Enjoy....
Thanks for the support. Unfortunately, they will only let me drive them around the parking lot . .and no loader workout on material . .only movements. And they don't have rental units other than the 4000 series . . .so I'm a bit blind. But from everything I've read here, owners of ALL the 2000 series JD's LOVE them and keep commenting about how surprisingly strong these little tractors are. . . so I'm sure I'll be happy!
   / Almost ready to sign . .is the 2320 the right choice? #15
Yep... I'm sure you'll be happy as well. You would find that any of the 3 machines are more than capable of handling most tasks. Sleep well and welcome to TBN... :)
   / Almost ready to sign . .is the 2320 the right choice? #16
mx125 said:
So you're saying that the 2520 is just better . . or that the 2320 will do no better with my needs than a 2305? (And that 2305 is definitely not up to the task?)
if you need the larger cutter and it does sound like you do, then I would definitely go with the 2520.
   / Almost ready to sign . .is the 2320 the right choice? #17
Yep, i went from the 4100 to a 4310, and i am kinda looking down the road at a cab series.
   / Almost ready to sign . .is the 2320 the right choice? #18
Overall, you list 3-point implements as a major player for use and I would clearly eliminate the 2305, but I would strongly consider the 2520 if you are set on running a 5' implements, because you may be greatly dissapointed in the performance of 18 PTO hp at the speed you want to cut.
I am still tossing and turning on that. I don't want to end up with an almost useless tool to save a few thousand.
If money wasn't an issue, I would def get the 25. It's just that for $22+ K cdn for tractor and loader alone, I start to think I'm way out of my comfort zone for my use. If I had income from farming . .it would be easier to stomach.
   / Almost ready to sign . .is the 2320 the right choice? #20
Have you looked at used 2520's. Seems those can be had with low hours within the price range you shoooting for.
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
Ford Super Duty...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
2017 E-Z Beever M12R Towable Brush Chipper (A51692)
2017 E-Z Beever...
2011 FORD F-550 (A53843)
2011 FORD F-550...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
