I may be all wrong, but here is my story and I'm sticking to it. Most chinese tractors use external voltage regulators. The charge condition of the battery will determine the draw (amps) on the alternator but the voltage regulator controls the voltage (push). You need a properly working voltage regulator to keep from applying too much (or not enough) voltage to the battery. My shop battery charger has a "boost activate" position which jumps the voltage up and can sometimes force a totaly dead battery to draw amps. By totally dead, I mean a battery that won't draw any amperage when charged normally. In any case, at around $15.00, the voltage regulator is often the first part to be swapped to attempt to cure a charging problem, rather than the alternator that costs more than 5 times that much. Many auto parts stores can test alternators. If the battery takes and holds a charge using a charger, and a voltage regulator swap doesned cure the problem it is a fairly safe bet it is the alternator. that is unless a wire came loose. Since we sell many times more regulators than alternaotors, I'm thinking they fixed the problem. Battery charging problems are about the only motivation for someone to replace either part.
Say that tractor wasn't washed with a pressure washer was it? if so check for loose wires. those things can put out a lot of force and move things around pretty agressively.
