Ambra Multi G-134 Substitute
   / Ambra Multi G-134 Substitute #1
KP Texan
Melissa
New Holland TC40DA
I'm doing some maintenance on my dad's TC40DA, and I'm having trouble finding info on suitable fluids for the hydraulics/trans. The original spec calls for Ambra Multi G-134 but according to the New Holland dealer, they're switching over to Mastertran Ultraction. Neither of these are cheap ($75 or so for 5 gallons), but it's worth it to me if there's no other good substitute.
That being said, I can get this oil at TSC for $30.00/5 gal pail: Traveller Universal Tractor Trans/Hydraulic Fluid (edited because I can't post links, but it is their Traveller brand Premium UTTO, SKU #80639199)
There are no good details on the TSC website but, assuming it meets M2C134D spec, would this work fine in this tractor? Anyone else use this fluid? There's also a bad leak I've got to track down (assuming maybe test ports), so I really don't want to be dumping expensive fluid out while I'm trying to find a fix for that. If it's not worth the $90 savings on my fluid change, I'll stick with the NH fluids, but I'm hoping it will work OK.
Thanks in advance for the help!
   / Ambra Multi G-134 Substitute #2
There's all manner of substitutes but few replacements. There are more opinions on this topic than choices.
Good luck.
Yeah, I've probably already used $90 worth of my time researching this, haha. What I might do is get the cheaper stuff to top off until I repair the leak, and then replace with the NH fluids when I do the complete fluid change with filter and all.
   / Ambra Multi G-134 Substitute #4
I use MobilFluid 424 in all my tractors. Meets NH, JD, IH, Cat, etc., specs. $40/5 gallons from the local fuel supplier and it's really good stuff.
   / Ambra Multi G-134 Substitute #5
Can I use Ambra Multi G 134 in my CK 2610 SE Kioti tractor?
   / Ambra Multi G-134 Substitute #6
I used the travelers tsc oil in my finaldrives and front axle recently on my 1720 only thing i could find locally that meets my ford/newhollands specs ive only got 50 hours on it but ill let ya know if it implodes and the oil seemed decent enough
   / Ambra Multi G-134 Substitute #8
CNH PowerPoint talking about Ultraction says it is replacing, Hy-tran, Master-tran, G134, and Nexplore. It is fully compatible with the older oils so a mix of older oil won't hurt your system.
   / Ambra Multi G-134 Substitute #9
Lesson learned cheap hydraulic oil causes issues from cavitation to pump issues. Spend the money on specified oil or spend money later on repairs. I experienced these hard knocks of life it痴 expensive. Some people don稚 have issues with cheap oil and probably drive their tires bald to squeeze out every dollar. I am not that fortunate.
   / Ambra Multi G-134 Substitute #10
Sorry to resurrect an old thread, but it appears that nobody carries the New Holland trans oils any more. What are you all using? What about warranty issues? This is a serious problem.
   / Ambra Multi G-134 Substitute #11
Our local Kubota dealer used Ambra Multi G 134 in all his Kubotas for years - no problems, and he thought it was a better HST oil than the Kubota oil of the time. That was before SUDT2 came out.
Have you tried ordering from Messicks? They still list New Holland G134 in 5 gallon containers at a reasonable price.
   / Ambra Multi G-134 Substitute #12
Do you not have a New Holland dealer? I just bought 5 gallons a week or two ago.
   / Ambra Multi G-134 Substitute #13
New Holland is restructuring dealers they are quite a few less in 2021. We have loss three in my neck of the woods. Lot competition in farm equipment segment. More coming on the compact tractor seen now we are seeing Bad Boy tractors rebadged TYM’s. I use John Deere trans fluid and Antifreeze in my tractors due proximity of dealers if it’s good for green it’s good for blue. Not afraid of cost . I have been bad side of tractor supply cheap oils resulting in unexpected repairs.
   / Ambra Multi G-134 Substitute #14
I went with the Mobil 124788 Delvac Tractor Hydraulic Fluid in my 20 year old TC29D so the Warranty is not an issue They say it's compatible with Ford New Holland ESN-M2C-134-D and FNHA-2C-201.00.
Be sure you use a good filter if you can't find a NH one. I had to use a matching WIX filter.
   / Ambra Multi G-134 Substitute #15
Sure do. Just bought a new tractor. He uses something called Naviguard. I don't want to mix it if I ever need to add. Likely will get NH from Messicks.
   / Ambra Multi G-134 Substitute #16
Once the warranty is up, I'll be switching to Evans waterless coolant. It's not cheap at $50 a gallon, and when you switch over you have to flush the system with their prep fluid to get the water out, but it's permanent, and can't cause rust. Haven't checked the new tractor but the old one said to change every year. That was a pain.
   / Ambra Multi G-134 Substitute #17
Last hydraulic oil/filter change( 2 years ago) on my Ford 1920 there wasn't any G134 at my dealer. Parts guy said they were now supplying Kubota UDT or SUDT(can't recall which) in place of G134. Had filter just no G134 and none on order. All information on Kubota/New Holland/Deere hydraulic oils to this point said do no interchange when changing oil because each has its own additives for the corresponding brand. Talked to service manager and was told that the Kubota oil was going into Ford/New Hollands coming into the shop. Went back and bought the Kubota oil. When returning to my truck, I noticed the lines and lines of orange tractors. Not one new blue tractor. The sign was also changed to just Kubota. Probably won't be getting filters or parts there anymore. Dealer is about two hours away. Don't visit them that often. 1920 has been a very good and trouble free tractor.
   / Ambra Multi G-134 Substitute #18
I am using TSC Traveller Premium hydraulic fluid in my Ford 1920.
I use Kubota UDT2 in my Kubota L48TLB.
I have never visited a Ford/New Holland dealer for anything.
It is either Messick's (UPS/USPS), or E-Bay for parts, or TSC for Ford hyd. fluid.
Messick's is absolutely great!
   / Ambra Multi G-134 Substitute #19
Me too, I used TSC Traveler Premium that advertises meeting Ford-134 in my 42 yr old Ford 1700 and never had issues. I only owned it for the last 15 yeras and only god know what the original owner used prior. i use Kubota oil onn my MX-4700 as I have access to my dealer (20 miles) and it is a rig I bought brand new.
   / Ambra Multi G-134 Substitute #20
I also used TSC Traveler Premium in my 2006 TC30 at the 600 hr change. Now at 750 hrs and no issues.
Unused 2024 Ray Tree RMSC78 Soil Conditioner Skid Steer Attachment (A59228)
Unused 2024 Ray...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
John Deere 3025E (A53317)
John Deere 3025E...
2006 JLG E400AJPN ELECTRIC BOOM LIFT (A60429)
2006 JLG E400AJPN...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
