. . . . and it's broke again. . . motor this time
   / . . . . and it's broke again. . . motor this time #21
I hate to say it, but I'm of a like mind... No engine issues with my 2007 2310 SCUT, but we bought a small RV for retirement that's based on a M-B Sprinter van. It's a 2015 model, with the OM642 V-6 diesel and the full complement of SCR, DPF, DEF, etc.
So far it runs great, gets great fuel mileage (about 20mpg, @ 8500 lbs).... BUT, and I mean BUT, the emission controls on this thing are a positive nightmare, and you can pretty much forget about fixing it yourself if something goes wrong with it!
I love the efficiency of diesels and I like clean air, but that's probably be the last diesel I'll buy.
My 2005 Jetta TDI wagon, OTOH, is still a real treat, I can fix it myself, and I'll probably keep it forever.... :)
   / . . . . and it's broke again. . . motor this time #22
Not me. I would rather have a pre 4 tractor with no electronics than a new one with, warranty or not. What do you do after the warranty expires and it needs fixed? it's not marketable at that point.
I know, trade up every 5 and take a beating on depreciation right? Reminds me of the Ford 'new every 2' commercial. Keeps the finance company in the black and your wallet empty. Myself, I don't play that game.
Bottom line is, Rudolph Diesel didn't envision his engine being choked with emissions junk.... and diesels really don't 'like' it anyway. Emissions hardware and processes add heat and heat is what kills an engine.
Both mine are Tier 3 which is no emissions what so ever. Have had zero issue with either and I farm with them and they both have thousands of meter hours on them with normal maintenance.
100% CORRECT!!!
   / . . . . and it's broke again. . . motor this time #23
:thumbsup:
my tractor is now 9 years old. still looks and runs like new. no real issues. and no tier4 junk
It's not really 'junk' emissions controls. More like lowest bidder components prone to fail and only last the duration of the emissions warranty (5 years) and then you are on the hook for (expensive) replacement components. Easy to understand why people do 'delete's' on them and why the government got on the bandwagon to eliminate that.
Like Kubota for example. The SCR/ muffler unit has a total life expectancy of around 3500 regens and then it's replacement time (and some units are sealed) while some can be taken apart and the element replaced / cleaned. Kubota is banking on (with 3500 regens) that the units are well out of emissions warranty which means at some point, the owner or next owner or next owner (but some owner) will be on the hook for a new component and they ain't cheap. Most likely the smaller Kubota's will never see 3500 regens but the bigger M series tractors, used for commercial farming operations will. Like me, I have 6000 hours on one of my M's. If it had SCR (it don't), I'd be in derate facing an SCR replacement (if one of the other components had not failed first). Like the now popular common rail injection. It's a complex system with lots of components that can fail. Give me the old HP injection pump and mechanical lift pump anyday.
Because both mine are pre 4, the only thing I might replace is the mufflers or a mechanical lift pump, maybe.
Sorry for the late update but I was hoping to post good news. Monday the local dealer tech came out and replaced the camshaft sensor. Engine threw a new code 723 / 08 instead of the 723 / 02 we started with. Not fixed, no real change.
Thursday the Massey rep came out with the local dealer and reset the ECU etc and did some more troubleshooting. No change, still broken. They are "expediting" a complete new engine wiring harness to swap that out. I'm not super enthusiastic at this point.
We already had our first snow of the year and instead of plowing with my new heated cab tractor I once again put on my snow suit and plowed with my 1942 Ford. :-( ****** and whine mode off*
   / . . . . and it's broke again. . . motor this time #25
Yi Yi Yi ! Sorry to hear that.
The bad news -- it ain't fixed. Never heard of that circumstance, but then mine is an older tractor.
The good news -- the right parties know it and know they have to fix it. Hang in there.
   / . . . . and it's broke again. . . motor this time #26
At least it sounds like your switch is working right, mine would be on and stuck on and gets louder as the days go by til things were fixed, but that my switch...........
   / . . . . and it's broke again. . . motor this time #27
We badly need a "Like" button on this forum in order to say we agree with someone. I like your comment there Oldpath05.
   / . . . . and it's broke again. . . motor this time #28
Amazing that the new tractor is out of service but the one from 1952 is up and running !
   / . . . . and it's broke again. . . motor this time #29
The OP apparently has a 2N
That would be 1942, rather than !952
   / . . . . and it's broke again. . . motor this time #30
Seems like they’d spring for a “loaner” while they are sorting all this out.
Did that ever come up?
Another week has passed with my tractor motionless in my driveway like a monument to my stupidity. Took a while, but I'm starting to get pissed more each day I drive past it.
No news from the dealer or AGCO.
Grrr . . .
   / . . . . and it's broke again. . . motor this time #32
You’re anger is very understandable at this point. I’d be furious by now, daily calling and emailing everyone I had a contact with in this process. I’d want them to cringe and think about me every time they opened their email or their phone would ring. That way I’d know they aren’t forgetting about me.
   / . . . . and it's broke again. . . motor this time #33
^^^^^yes, at least keep their attention! I wouldn't get pi**ed with them, keep it courteous, but very firm for sure. At least an update....
   / . . . . and it's broke again. . . motor this time #34
How many hr on new tractor, how long has it been just sitting in driveway, how often has the dealer been out to look at it, how come its not in the shop, how much did it cost, how many new tractors can be bought, how much is new tractor with cab needed................... Nice to see some people are still able to be courteous at this point and not get pzzzzz, must be something wrong with me.............
I guess this what the tractor looks like.... Massey Ferguson 1735M With Cab and DL125 Loader - YouTube
   / . . . . and it's broke again. . . motor this time #35
Is it insured for acv or compensated 100% loss payable? If it's 100%, roast it and call it good and buy a good used Pre-4 unit (if you can find one that is). Pre 4 units are bringing top dollar today as farmers and contractors are getting wise to the pitfalls of computerized T4 final engines and lowest bidder components.
Probably make a nice BBQ in the driveway. Blame it on an electrical failure in as much as you already have an electronics failure. My recommendation is roast it and move on.
Yeah, that is the exact tractor I have.
Considering turning it in to insurance at this point.
   / . . . . and it's broke again. . . motor this time #37
Sorry you are going through this.
Probably the worst time of the year to get service to boot.
I see this kind of stuff on complex cars, especially BMW. It's always something stupid, that takes a lot of time to find.
Contrary to popular belief, these modern, over engineered systems are actually easier to service. However, when things like poor quality electrical connections are thrown into the equation, they quickly turn into a huge headache.
Most of the time, the computer tells you what's wrong, and then it's an easy fix. But, they can never tell you if the fault is actually not a bad sensor, or computer, it's just a bad wire.
Once enough of them have been made, and serviced, problems like this are discovered, and moved into the easy fix column via the internet and service bulletins. But, that never makes the owner who was caught up in it, feel any better.
Hopefully, they will figure out what is causing this, and you can put it behind you soon.
So the dealer was supposed to come up today to replace the wiring harness. But, they decided not to since it's going to be a two day job. Instead they now say it's my responsibility to get the tractor to their shop ~35 miles away. Mind you it doesn't run properly, if at all. I've been afraid to even run because it sounds terrible and has no power.
Called AGCO and they were as helpful as usual, i.e. the customer service rep did their best to placate me and tell me they would see what they could do.
I'm thinking it's just turn it over to the insurance or lawyer at this point.
   / . . . . and it's broke again. . . motor this time #39
2 days to replace a wiring harness? Thats a 2 hour job at best.
   / . . . . and it's broke again. . . motor this time #40
After 5 weeks and no solution, no customer service if ther're telling you "it's your responsibility to deliver/pickup your tractor", I think I would be screaming a powerful email to both the dealer and MF...
Hope you get a solution very soon,
KC
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
2001 John Deere 6210 (A60462)
2001 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
