Andersen Slider - Cladding Peeling Off
/ Andersen Slider - Cladding Peeling Off #1
MGH PA
Northcentral, PA
2005 Gravely 148Z 48" ZTR
Has anyone experienced this with Andersen products? I'm reading that it's fairly common, unfortunately. I don't know the exact date of the sliding door, but I think the addition the previous owner had done was in 97 where this door is located. Anyways, I just noticed this when I went to slide the screen door shut and it got hung up. Upon further inspection, I noticed, that it's pretty bad (see pictures below). I know it's out of warranty, and I'm not really wanting to have to replace the whole door. I wonder if there is a way to just reclad these two sections?
Has anyone experienced this and if so, what did you end up doing?
/ Andersen Slider - Cladding Peeling Off #2
This is probably not much help, but our Anderson french doors did the same, but during the warranty period. I filed the claim with Anderson, and so did the contractor. Contractor picked up doors from the lumber yard, and there were two sets of doors. He said he only needed one set. Lumber yard said, they sent two sets, take them. I still have one set in my garage, if it should happen again.
/ Andersen Slider - Cladding Peeling Off #3
I tried to use the warranty on ours, they would only completely remove the doors and I believe they said it would take days to re-install.. then only pro rated.. I was going to sell anyway, so I used adhesive and white silicone.. not happy with Andersen...
/ Andersen Slider - Cladding Peeling Off #4
There is a small stamp on the corner of the glass.. has the Andersen logo on it as well. Take a pic with your cell phone and blow it up..the date the unit was manufacturered is stamped on it.
1st quarter 1996.
I have Andersen 400 series speced out for our new build, too. Hmmm.
/ Andersen Slider - Cladding Peeling Off #7
I have had Anderson doors in a house since 1994 no problems. They were triples morning sun. Still in the house to this day although I moved in 2006. Over the past 10 years I have put in 5 400 series sliders still happy customer in the home we are in now
/ Andersen Slider - Cladding Peeling Off #8
...I wonder if there is a way to just reclad these two sections?...
A siding/aluminum contractor can probably break white enameled aluminum and encase the jambs etc...
/ Andersen Slider - Cladding Peeling Off #9
I have Andersen windows and doors on a "3 season room" at my house which were there when I bought it. One of the doors had some of the cladding peeling. The door was just under 10 years old and Andersen replaced it. Now, 8 years later, the new one is peeling again, as well as one of the others. I'm not sure what I'm going to do with it. This is happening only to the doors that face west and get very hot in the summer. In general I like Andersen products. I have two sliders that don't get the extreme sun and they have no issues. Also no problems with the windows, just those two doors in extreme heating conditions.
/ Andersen Slider - Cladding Peeling Off #10
When I built my PanAbode home here in '82, I added one window that was not part of the PanAbode package. Its an Anderson - crank out window. Its still in great shape. This window faces toward the NE and never gets the heat of the afternoon sun.
Yeah this door faces west.
/ Andersen Slider - Cladding Peeling Off #12
Our east facing Andersen 400 series French doors had some of the vinyl cladding peel and pucker. I cleaned and reglued with Gorilla glue...used a board just as long as the loose clad and clamped it tight until the glue dried. That was 3 years ago and still holding tight.
We've had no problem with the other Andersen doors, which open onto covered porches, or any of the windows.
Good luck.
/ Andersen Slider - Cladding Peeling Off #13
My door trim was peeling off but not nearly as bad as yours. Just this week I got it back close to where it is supposed to be and put some elastic sealant on it. It is pretty sticky stuff and looks good for now. We'll see how it stands up in the weather on the west side of the house.
This is the stuff I bought at Ace Hardware. I used white, I didn't see a page for white.
https://www.acehardware.com/departments/paint-and-supplies/caulk-and-sealants/caulk/17531
/ Andersen Slider - Cladding Peeling Off #14
MGH PA, I do believe that after 20+ years, any window or door would be having some issues. I have found Andersen to be a trusted product and would not have a second thought about using them on your new house.
/ Andersen Slider - Cladding Peeling Off #15
3 season room here. Used Andersen "French Wood" sliding door. Entire bottom covering outside on the fixed panel started peeling off within a few years. I used screws and glue to hold it on. Looks like crap, but it works. I did file a claim and got a new panel, but it's still in the carton in my shop, I haven't bothered to pull the door apart, try to stain the replacement interior to match and use it.
/ Andersen Slider - Cladding Peeling Off #16
Happened to mine on back of house that gets direct weather. Anderson shipped me new doors that i installed. I still have the old doors, that i would like to fix.
/ Andersen Slider - Cladding Peeling Off #17
BEF, how long had you had the door? Still under warranty?
I had a couple of window cranks break when a wind storm caught the open windows and jerked them - Andersen was real good about sending replacement cranks.
/ Andersen Slider - Cladding Peeling Off #18
They replaced the doors once under warrantee. The replacement doors have not peeled off.
/ Andersen Slider - Cladding Peeling Off #19
I agree. All Anderson 400 series in my house and Moen faucet products. They have both had amazing after sales support. My Anderson East facing sliding door takes a lot of abuse with the kids, but is holding up well. The screen slider though is another story, but ~15 years on an aluminum screen sliding door is probably pretty good.
/ Andersen Slider - Cladding Peeling Off #20
I used several of the higher end windows for remodels and new construction...
Of those I like Marvin... never a problem and some going back 20+ years...
Anderson had issues that were covered and those homes are all have new owners now.
Anderson does a lot of advertising...
On the other hand... the windows on my 1922 Craftsman are wood double hung... I did have to replace the sash cords... Mom's home is mid 1950's aluminum casement... those too needed replacement cranks once...
My guess is there is not a perfect window out there but the Marvins have been tops so far.
