Another closed thread because of politics @Egon
   / Another closed thread because of politics @Egon #61
   / Another closed thread because of politics @Egon #62
I was surprised it lasted as long as it did. For me, I just like to ask very simple questions and see if any of the believers reply. Most seem to be focused on the more complex aspects of global warming and over think it. I guess that somehow allows them to ignore the basic lies that it's taken to push global warming. Others are justifiably concerned with pollution, and use that concern and global warming to try to do something about it, regardless that they are totally different. I'm all for a cleaner environment, but I'm against increasing taxes and regulations to stop something that isn't happening so lobbyist can get billions of or tax paid dollars to continue pushing an agenda. Green energy has already caused more damage to the planet then oil ever will.
It's just a matter of time until this thread gets closed down too. Might as well have fun with it while it lasts.
Oh God,,,, how I wish I had said this.... Good post Eddie!!!! I like your new avatar, is that a Ford/New Holland 555????
   / Another closed thread because of politics @Egon #63
I look at everything in pros and cons. What are the benefits and what are the negatives. If there is an overall benefit from something, even though there are negatives to it too, then I'm all for it. This is also how I look at the global warming debate. Do those who tell us how horrible it will be have any positives to it? Why not? History has proven that warmer temps have been more productive times.
Oil is the lifeblood of civilization as we know it. It provides more energy then any other source out there, it's readily available, it's to the point that it's cheap to produce, and you get a great return on it for what you use it for. Pollution is a negative from it, but I feel it's a something that we are improving and will continue to improve. So in the overall scheme of things, oil usage is a huge plus for mankind.
Green energy is a method to generate power to replace oil based sources. There isn't a single green energy source out there that actually works to replace an oil based source. Everywhere there is a windmill farm or solar field, there is still a power plant operating because green energy isn't reliable. Add to the math that windmills cost more to operate then they generate. The resources used to create them are mostly a negative other then they create jobs for people in China and India that build them, and here who install them. Where i'm from in CA, one of the first windmill farms was built at the Altamont Pass. This was a big thing at first, but over time, they started falling apart. A good friend of mine owns a crane business and he was repairing the equipment used to maintain the windmills there. It was a huge money pit that went bankrupt. No amount of money could keep them going. And instead of making windmills better, GE got the majority of the contracts to build them in China, they just keep building them the same since the Fed Government is paying for them, whether they do anything or not. Which is also why I think GE is in big trouble financially. They put too much into green energy and have become too dependent on Federal funds to keep going. Tesla is another one that probably wont make it because they are putting out junk a with massive influx of Federal money.
Australia just spent billions building a battery to back up their windmill farms. That battery will last for 30 minutes,then they are out of power. Only government is that dumb.
How many homes have mercury filled light bulbs in them that are toxic and if broken, you are supposed to call in a hazardous team to clean it up?
How much lead and acid is now piling up in used batteries from green energy vehicles that must be disposed of? How much oil is used to create these cars and then charge them up so they can operate?
Ethanol was a horrible idea to supplement gasoline. It takes more oil to create it then you get out of it. It contaminates massive amounts of water and it removed huge amounts of cropland from food production. It ruins engines, and it reduces fuel economy in every vehicle that uses it. CA went even farther and added MTBB to gasoline to green up the environment without realizing that it poisoned the water table under the ground. Now you can't drink well water in any of the big cities because green energy has been so horrible there. Even using it to water your grass is dangerous because of animals drinking it.
LED's are a benefit from green energy, and there are a few other things like better insulation in homes, so there are some positives to it. But until the free market is accountable for what is created, we will just keep repeating Solyndra by giving old technology hundreds of millions of dollars to stay open when all they have to offer is old solar cells that don't work very well and cost more to make then you can buy at the store coming from China.
There is no shortage of oil. There is no such thing as green energy that actually works. Focusing on improving oil and fossil fuels makes more sense then paying for something that accomplishes nothing. If and when solar or wind actually produces more then it consumes, there wont be any need for the Federal Government to force it on us and use tax money to keep it operating.
Dangit,,, another one I wish I'd said........ Eddie, you're killing me...... :cool:
   / Another closed thread because of politics @Egon #64
Yes; all true and good and understood long time ago. Now the only part left is how does all that moisture get into the clouds if all is below freezing?? It should require a considerable amount of precipitation for ice cap formulation that may be miles thick.
Google says this- On warmer days, when temperatures are above freezing, we can see the melting process as snow leaves water behind on surfaces, which then evaporates or gets absorbed by the ground.
We do not see the sublimation process because the snow goes directly into water vapor without first melting into liquid water.
   / Another closed thread because of politics @Egon #65
It's a subliminal thing.
   / Another closed thread because of politics @Egon #67
The topic/main subject of this is not in any way accusing Egon of anything...just trying to get his attention on where were left off in the closed thread...
The recent Climate intensity thread in the snow removal forum was closed because someone went over the top with partisan political rhetoric...Yes the thread topic pushed the window on tolerable discussions that have political overtones... But it's too bad it had to be closed...
To carry on...
Well Sir
A thread just closed in rural living and my finger prints are nowhere to be found. What was that reference to tolerable discussions?
Well Sir
Evidently the tolerable window was exceeded...but then again...when goofs (with poor memories) start direct name calling and making personal threats it does not help...
   / Another closed thread because of politics @Egon #69
Evidently the tolerable window was exceeded...but then again...when goofs start direct name calling and making personal threats it does not help...
You mean like calling a Man's Son/Grandson idiots??
   / Another closed thread because of politics @Egon #70
That thread needed closed. See they already started new thread to continue.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
Brush Cutter (A50322)
