Another generator query
/ Another generator query
A 3/4HP 220v motor that is 50-70% efficient will need 3.5 to 5 running amps (750 to 1100 running watts) and 10.5 to 15 amps or 2310 to 3300 starting watts
Aaron Z
Interesting...not that I'm doubting your #'s but my 1/2 HP 240V set at 110' draws about 4200W on initial start up confirmed by the watts gauge on my transfer panel...if it's accurate. I'm waiting for an amp probe that I ordered to confirm actual amperage drawn during start and running.
Thanks for the info guys, I greatly appreciate it!! We got power back this afternoon, but it's been on and off a few times. Back on now, but for how long?
A buddy who got power back loaned me his genny yesterday, and it was nice to have running water again!! Since it was a borrowed unit I was very selective on how much load I put on it. I paid close attention to the wattage drawn and as I just mentioned, I was a little surprised my well pump drew about 4200W at initial start up. Then I noticed the coffee maker drew about 2100W at start up(then back to about 500W after it finished) but every few minutes or so it would surge up to 1500W for a moment. I assume this is due to the heater element. I made a mental note about the wattage for several items, but I plan to go back again and test run all the basic needs and write it down. When I get my amp probe I'll repeat the tests and measure the actual amperage. The reason for doing this is...based on my observations this AM...I'm starting to believe I overloaded my 5500XL last fall with Irene and caused the well pump to fail.
With that said...I'm on to my next query...a larger generator.
Just spent the last hour looking online and if I'm not mistaken, all the portable Honda units are splash lubrication? If so...Honda or not, forget it. Just my opinion though if what I found is correct.
So now back to Generac...so far, my research and what I've heard about them is above par, in general. Some negative comments but those were mostly the lower end units. The larger units had rave reviews. I found this model and it was love at first sight:p Might be a little overkill but I would think this unit will remove any chance of overloading again. At least for my usage and I do plan to test each and every item I want to run during an outage and document it for future ref. Amazon has this unit for $2700 but Sears has it for $2042, which I'm currently exploring.
Any comments, suggestions or opinions about this one would be appreciated!
Thanks!!
Speaking of overloading a generator...
I'll skip all the details but when I first noticed the well pump problems last fall during the Irene outage, I shut off the transfer panel. With the genny running-no load, I found one side of the 240V was dead...no voltage measured at the genny itself. The other side read about 108V IIRC. Shut it down and pushed it in the corner. I did pop of the end cover of the power head and nothing burnt or loose or any odor. Figured it was dead.
A year later...thanks to Sandy... a discussion else where led me to investigate and test a little deeper. Before I proceeded, I started it up and measured voltage again...no load just to verify my last tests. NOW it reads 128V on both sides. Prior to connecting the gen to the house, I thought I had found a cable/plug problem because I only measured 26V and 90V at the plug for the house cable. Took apart both plugs and nothing found. Put the plugs back together, read ok now. No idea what happened there but it read 128V on both legs going into the house. Fired up the genny, switched on a couple circuits at the transfer panel. Just lights at first which were nice and bright. Lamp outlets in the house read 126-127V as well. Flipped on the fridge(empty) and it too was fine and within an hour it reached operating temp. Left lamps and fridge on for 3 hours and all was good. No well pump yet as I was still concerned about smoking it again.
Next night with just 2 lights and the empty fridge running, I noticed a rapid flicker with the lights...fridge light included. Added a resistive load (toaster) and no change...still flicker. Forget it, all bets off and I'm not taking chance with this genny again. Being a big box item, didn't feel confident it was worth putting any $$ into a 12 yr old gen. Then I get my buddies genny...a Honda 5500W/6500W and his did the same thing with the rapid flicker. Was told this is a common problem with single cyl gensets. yet during the handful+ times I used my 550XL over 12 yrs, I never noticed this rapid flicker other than the normal dimming when a load was put on it.
Any comments about this matter?
How or why did the genny fix itself with no repair? I did hit the breakers last fall and again this time, maybe a breaker on the genny?
/ Another generator query #24
Thanks to sandy, 18 in of snow high winds and trees all over, my titan 7500 saved our butt. We are in our sixth day without power and I got tired of cold showers. Today reading a generator thread i ordered a rural king 15000 pto gen. This our second outage in 4 months. Now that we got the big one we wont have another outage for years, although I hear there may be another noreaster on its way. Be safe
/ Another generator query #25
A large part of that is probbaly due to the distance and wiring. Those numbers are with a motor getting a full 120 or 240 volts. By the time you go 100' across the yard and 100-500 feet down the well, you may be down to 105 volts at the motor itself and as such, you could use lots more the watts that the motor's nameplate says.
Someone on here mentioned that when he switched the wire in his 200' deep well from 12 gauge to 10 gauge, his 5500 watt generator which would could JUST start it before (and then only with nothing else running) could start it without much fuss (I might be mis-remembering the depth and generator size, it was a while back).
Aaron Z
Aaron Z
Good point and glad you mentioned voltage drop. I need to shorten my 10 gauge cord for the genny from 35' to 15'
I'm no electrician, but what you said confirms what I understand and glad I replaced the pump wiring with 10 gauge when I did my pump last fall.
/ Another generator query #27
TC you don't mention what your current generator is so I'll ask a general question,, have you checked your brushes "if it has them" on the unit ?? They could be hanging up or worn,, "making sometimes and not others",, If the voltage reg. were bad it should just stay the same or get worse..
TC you don't mention what your current generator is so I'll ask a general question,, have you checked your brushes "if it has them" on the unit ?? They could be hanging up or worn,, "making sometimes and not others",, If the voltage reg. were bad it should've just stay the same or get worse..
Generac 5500XL 5500W rated 6500W surge purchased 1999 from HomeDepot. About 130 hrs on it now 100 or so was from Irene.
No idea if it has brushes or how to access them without major disassembly...or so it appears. Someone was willing to walk me through some diag earlier this week but when i found the voltage output ok i decided to give it a try again.
The rapid flicker...not severe but noticeable ... with the house lamp gave me enough concern to stop using it. Never noticed it before and yet my buddys Honda causes the same thing. Normal?? Don't know for sure but told it was with single cyl generators.
Edited to add...i now believe i overloaded it towards the end if the Irene outage.
/ Another generator query #29
Good choice. Honda motors are hard to beat.
/ Another generator query #30
Yes, if the wire is close to, at, or below the minimum size for the application, you can get a much higher current surge on start up than normal. Cable length is of course, also a factor.
When in doubt during installation, spend the money, and run a larger cable.
Some fast flicker is noticeable on some of my lighting, when I use my generator. If you spend enough money for a generator, I am sure they buffer it out.
I experience an outage exceeding 3 hours, on the average of once every 12 years here. So, though I would love to have a massive, propane fueled, automatic standby generator, it's not economically sensible for me.
/ Another generator query #31
Do you have a Kil-a-Watt? It's a digital meter that you simply plug in to a wall socket and it will show you the voltage as well as the hertz. If your lights are flickering it might be because you ar getting something less than 60 hertz. The Kil-a Watt also can be plugged into any 120 volt appliance to show you how much power it draws. Many places sell them including Amazon for around 20 or 25 bucks.
No kill a watt meter but my Fluke 87 reads HZ and shows it to be varying slightly from 60.2 to 61.9 so avg is about 61. I ordered a Fluke amp probe for actual amp useage each item draws.
The wattage i got directly from the transfer switch panel as it has a meter.
/ Another generator query #34
Have you checked the capacitors? If they are going bad you would notice 1st effect when they are hot. If you caught it quick they would get better when cooled. Fairly cheap to replace.
As for starting current, the currentdrain will RISE with voltage, BUT decrease in duration because the motor will start promptly. Typical single phase motor locked rotor current drains are about 4x the running drain. Many gens see a momentary overload and lose full voltage output resulting in slow or no start. [Note that start Watts = V x I are down mostly because of the voltage drop.] Fortunately, well pumps do not start under a hard load, rather they develop load as they gain rpm. Consequently, most will start [kinda sluggishly] at 3x. Your gen either does not lose V, or does not account for it in its wattage computation. I think its the former because its well below your gennys rating.
larry
/ Another generator query #35
Read somewhere on another forum about lights flickering. Seems that on smaller cheaper Chinese sets they used capacitors for some sort of voltage regulation. The units with the problems didn't have "proper" voltage regulators. Replacing the caps was the solution. Don't know anything about that type of system but thought that wasn't a good way to go. After 8 days with no power because of "IKE" I broke down and finished off my 401k by purchasing a 16kw diesel with bells and whistles which included a dedicated voltage regulator. So far so good. Only have about 30 hours on it under load but has worked well for the 2 occasions we needed it. Also bought a 400 gallon diesel tank and 12v pump so I can fill the generator and pickup. Getting too old for unscheduled campouts. Best of luck and health to all!
larry
I'm not familiar with the power head for this gen, however I'll keep the capacitors in mind after I get the manual downloaded.
Thanks!
Hmmm...that makes sense. In fact the loaner my buddy let me use might qualify as a chinese unit? Came from Northern Tool and is Honda powered, but the power head? I wouldn't be surprised if it was some no name off brand.
I say that because now I know what a Honda genset really looks like. Decided I don't want to take a chance with the my old unit even if I fix it. Spent quite a bit if time researching and decided I'd pass on the Generacs. So I bought a real Honda this time around. An EM6500S. Hope it lives up to the saying...
"Buy a Honda--buy it for life"
I'll get it next week and after playing with several models in the Honda showroom, I'm confident this model will suit me and be the last one I have to buy!! Not as quiet as the EU series, but It's definitely quieter than my generac
Thanks for all the help gentlemen...as I'd still like to fix my old Generac and maybe give it to my daughter or sell it. If I get the manual for it, I'm sure I can trace the fault down, or at least find the weak component as it is working at this time.
