Antifreeze- is any type OK?
   / Antifreeze- is any type OK? #91
Oh, another thing. Don't ever do radiator drain and fills either. When the additive package in antifreeze wears out, it becomes part of the salt and calcium buildup in the bottom of your radiator, engine block, and scale everywhere in between. If you just add new coolant, the additives just "attack" the old build up in the radiator, block, and scale, then are not suspended in the coolant any more and become part of the same problem. Reverse flushing with chemical flush kit is the only way to go. It goes against the scale, breaking it down and suspending it, allowing it to be flushed out.
Actually what happens is that as antifreeze ages from heating cycles it becomes acidic. Combined with additive precipitation such as silicate additives found in LD auto antifreeze which will fall out of solution especially when the coolant pH gets down to less than 8.0 pH, thus a form of sludge accumulates in the bottom of the water jacket where coolant flow is much less turbulent. It settles there allowing the acidic sludge to corrode and rust the freeze (core) plugs. When they show signs of coolant leakage such as a crystalline deposit or dampness associated with coolant leakage, replace all the plugs not just the one. While all are removed use a garden hose to wash the lower end of the cylinder block and you may need to physically break up this gelled sludge as well. Replace the plugs then flush the engine with a two part powdered acid/alkaline cooling system flush such as Prestone manufacturers. Follow their instructions carefully. Failure to do so may result in the system being left in an acid or alkaline state instead of neutral.
As for "salt" the term is actually derived from the coolant additives which in dry or powder form are referred to as "salts" but not actually sodium chloride salt. Sodium silicate, sodium nitrite, sodium molybdate, sodium borate, potassium phosphate are examples of such inorganic salts used in coolant additive chemistry. These salts with the exception of sodium silicate are classified as "super soluble" meaning they dissolve readily and are very resistant to dropping out of solution (precipitation). However, sodium silicate does not enjoy such a reputation. It can be easily forced out of solution. Even coolant concentrate with silicate can have the silicate additive precipitate while still in the jug! It forms a white gel that is quite solid. Once formed is very resistant to redissolving, certainly not with anything less than the strong agitation that a water pump impeller can impart.
The good news is that the addition of new coolant to an old system does not chemically attack the old additives and cause problems. Depending on your coolant formulation and premix solution, there should be little to be concerned with in adding coolant to a low system. I do agree that just draining and refilling with new coolant without benefit of flushing is a bit of a wasted effort.
Scale formation in an engine is due to use of hard water when making coolant premix. Scale has to be chemically removed by use of strong acid flushing agents or use of chelating cleaners formulated to remove scale. Scale can not be easily removed especially not by flushing with water.
Here is a simple coolant maintenance program for diesel tractors (but can include your diesel pickup):
1. Start clean. Flush the system with a chemical cleaner following manufacturer's instructions. Do not take short cuts on this.
2. Fill the system with a 50/50 premix unless your climate dictates a 60% antifreeze/ 40% water solution (-64*F F.P.). Use premix coolant that has the necessary diesel cavitation protection chemistry already added. You may add it yourself as you make the premix coolant solution.
3. A good target nitrite content is 2000 - 2400 PPM nitrite. Use a test strip to determine that. Or use Fleetguard DCA4 liquid at 6.5 ounces per gallon of premix.
4. Whenever the system is low, use the same coolant mix you filled with or one that is chemically similar. Meaning: the color can be different but the amount of glycol/water should be 50/50 if that is what you started with. The additive chemistry should be mixed at the same rate as when doing the first fill.
5. Test with test strips at least twice yearly if you only put on a few hundred hours of operation each year (season).
6. Properly mixed/formulated coolant with this maintenance will last for up to 5 years of operation assuming you can put on 2000 hours of operation. Coolant has a lot longer life when properly maintained than what the OAT coolant manufacturers want you to believe so that you will buy OAT to get "long life".
   / Antifreeze- is any type OK? #92
Fieldserviceengineer, thank you for the excellent posts. Something that I thought was a simple thing (antifreeze) seems more complex than Einstein's theory of relativity.
I went to a couple 3 hour classes on antifreezes, oils, and fuel(reformulated) a few weeks ago, put together by BG. It was very informitive. A lot of what you have written was mentioned by the instructor giving the class. He said there was a lot more that he would like to go over, but... well, how much can you really teach someone in just 6 hours. One of the points he made though, was that 90% of the problems on todays cars, trucks, etc.. are caused by chemical reactions. And the best way to fight chemical reactions was with chemistry. Heck, I have to hit the search engines when I want to know which wheel bearing greases I can mix. It's funny how the engineers building the motors get all the praise. Glad to have guys that help them last long too.
   / Antifreeze- is any type OK? #93
i am glad i read this thread, guess my prestone is going back to autozone, and i will be going by the equip co to figure out what they have for AF. does anybody have a good, effective and simple method of flushing? i am in the middle of going thru my kubota tg-1860, 3cyl diesel, i hate to rip the hoses apart just to flush it, they look real good, but i bet they would not come off without a fight.
   / Antifreeze- is any type OK? #94
We have mostly older stuff so we use the old green style in everything. I like to use the Prestone Cleaner (not the Flush) for about 6 hours of total run time with three well water flushes before and afterwards before putting in the new antifreeze.
   / Antifreeze- is any type OK? #96
   / Antifreeze- is any type OK? #97
For those who may be interested-- there's a concise, informative article in the current edition of Popular Mechanics that discusses anti-freeze types, diffferences, applications, etc.
It's in the "Car Clinic" section, p. 95.
   / Antifreeze- is any type OK? #98
i was trying to get some other flush ideas relative to the great info provided by (Fieldserviceengineer) from above.
After returning the prestone to autozone i went to the kubota dealer hoping for a good outcome. I picked up a jug of Fleetguard as noted above, as expected the guys at the Kubota dealer looked at me like I had 3 heads saying they never flush and only change AF at customer insistence, when it looks dirty or shows signs of oil. I Stopped listening to them yahoos right there. Went by the CNH store and met some real good fellas. They said not to use the packaged flush, their routine was to drain system completly, mix cascade dishwasher soap in a bucket of very warm water, pour it in with the motor running, then drain and run clear water thru it. I intend upon using distilled for a final clear rinse and then put the FG AF in. Funny thing, the test strips and that part of the maintenance process from above was for the most part not known at either shop.
I guess the most important question I have if anybody know much about the Kubota 3cyl diesel, are their bores wet sleeves? i will use the correct AF anyway, would be nice to know what I am dealing with.
thanks
   / Antifreeze- is any type OK? #99
Wyatts Dad,
Flushing with Cascade dish washer detergent powder is for removing lube oil and fuel contamination. For general cooling system flushing to remove rust and scale you are wasting your time. Use the Prestone two part cleaner. Fleetguard Restore Plus is very effective (costly too) but the Prestone is very effective at removal of rust and scale. If you are not having any issues with oil, fuel or indications of rust or scale formations, then simple draining and flushing with plain tap water is quite sufficient. Flushing with distilled water is a waste of time for the short time it will be in use. Distilled is fine when mixing engine coolant which will be in for the long haul. If you have any further questions you can contact me at 800-223-4583, follow the menu commands to Technical Assistance and ask for Gary Spires at ext. 9418. Should you end up with Customer assistance, ask for me at the same number.
DUSTLESS SAND BLASTER (A52706)
DUSTLESS SAND...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
Duetz Power Unit (A50120)
Duetz Power Unit...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
