Antifreeze- is any type OK?
   / Antifreeze- is any type OK? #71
"I have a 3 year old New Holland TN65D diesel tractor. The hours are low(225) but I decided to change the antifreeze since its 3 years old. I drained out the green antifreeze and filled it up with a 50/50 mixture of Prestone antifreeze and distilled water. I read somewhere that I need something different or an additive package to help in my diesel. What goes? I have checked at every auto store, Walmart, and even a few tractor dealers and they don't have anything special. My New Holland dealer said the regular green Prestone is OK, the people from Prestone say I need their Heavy Duty Extended life Antifreeze for my tractor! Is this true? Who do I believe? I am ready to put the old green stuff back into my tractor! I need green heavy duty diesel antifreeze or what? This is really nuts! Any advice will be greatly appreciated."
Sorry to be so late in replying on this matter. This happens to be an area of expertise for me as I am a field service engineer for a division of Cummins. First, if the CNH dealer parts guy told you what coolant to use, trust what your tractor/engine operation and maintenance guide calls for. I cannot tell you how many times I hear that service recommendations are being solicited from the Parts guy. Even some service managers at dealerships are clueless and have quick opinions. The O&M guide is you guideline. Sine CNH uses a lot of Cummins engines and likely you are talking about the engine model, QSB 5.9L then from Cummins' point of view on maintenance, the coolant can be one that may not have SCA (supplemental coolant additives). However, CNH factory fill coolants now for their machinery are using coolant products fromulated with additives for the prevention of cylinder wall cavitation (liner pitting). The QSB 5.9 and earlier versions of the B5.9L never required the use of an SCA because the engine has NO history ever of a cavitation failure. If you are running larger engines such as the C8.3L or now ISC or ISL, those engines because they do have a history of cavitation failures if the coolant is not properly formulated and maintained with a suitable SCA will experience destruction cavitation failures that will result in at least an in-chassis overhaul. If you are not running engines with liners (sleeve) cavitation is still possible depending on the engine make.
The Cummins B5.9L, ISB, QSB are not linered engines instead they have what is referred to as a "parent bore", it is cast into the cylinder block. In these engines, cavitation failures are not known in either automotive use, industrial or generator set applications. The new generation B engines, 6.7L are also parent bore but with no cavitation pitting known at this time.
One of the oldest parent bore designs that is a known "pitter" is the Caterpillar 3208 as used in Steiger and the old White (4-225, 4-250) tractors plus plenty of medium duty trucks. Without adequate chemical treatment on a regular basis with a suitable SCA, those engines would fail.
Ford PowerStroke (International D444E) 7.3 turbo, 7.3 NA (no turbo), 6.9L all are known to suffer cavitation pitting failures. The newer 6.0 and its replacement are no different. All these engines are parent bore design.
To be able to sleep at night, use engine coolant that are formulated with SCA and not antifreeze that you have to add the additives to. There are several brands available. Almost none of them are available at Walmart or even auto parts stores. You need to go to a Heavy Duty dealer. Ag dealers who sell HD Fully Formulated Engine Coolants are: John Deere (Koolgard), CNH, Caterpillar (DEAC, not the ELC). Heavy truck dealers such as Kenworth, Peterbilt, International, and Volvo sell fully formulated coolants. Many of them also sell non-treated green colored coolants. Those will require that SCA be added by you when you mix the coolant with water. If you liquid additives such as Fleetguard DCA4, Penray Pencool, Caterpillar additives, the typical treat rate would be about 5 ounces per gallon of mixed coolant.
Keep in mind that the precharged coolant will deplete over time as the engine runs. These SCA chemicals are sacrificial compounds that will dissipate as the engine runs. The higher the engine load factor, the faster the SCA is used. When you have low coolant levels from leaking, refill with the same precharged engine coolant. If your engine has a coolant filter that has the additive in it, those additives are typically quick dissolving. When the coolant leaks, those additives are lost as well. The coolant filter of a given chemical charge size are sized according to what the engine is expected to consume by running, not by leaking. Leakage consumption is replace by proper coolant refill.
Feel free to contact me: ax684@cummins.com
   / Antifreeze- is any type OK? #72
FYI
after reading this thread, a couple of days ago while walking the automotive
dept. at WalMart, bought "Final Charge Global" anti-freeze, 50/50
mix, on clearance for $5 a gal. while supplies last ? made by "PEAK", meets or exceeds OEM spec of :
CAT EC-1, Cummins 14603, Detroit Diesel, Mercedes DBL 7700. Will use this antifreeze for the spring maintenance
   / Antifreeze- is any type OK? #73
At $5 a gallon that would almost tempt me onto a CommieMart parking lot, almost. :) That's a heck of a good price.
   / Antifreeze- is any type OK? #74
On a side note, my Ford F350 manual recommends changing the coolant @ 5 years or 100K miles which ever comes first. It's got only 77K miles but the five years are up so I plan on switching out the coolant with ELC this weekend.
As others have said if you go with an ELC you need to flush out the entire system and use distilled water.
Anti-freeze maint. is just as important as changing other fluids in your tractor, car, or truck.
   / Antifreeze- is any type OK? #75
5$.. man.. that is good..
soundguy
   / Antifreeze- is any type OK? #76
FYI
Final Charge is the only OAT (organic acid technology) coolant that has actually passed the Cummins Engineering Standard 14603. The importance of that for tractors and other applications with Cummins engines is that this coolant has a demonstrated ability to NOT attack elastomers such as silicon rubber edge molded gaskets and Buna Nitrile O-rings and it has good cylinder wall cavitation pitting protection. Final Charge's claim of meeting the Caterpillar EC1 spec is also true. That spec calls for a major field test which OWI paid for. That was done and the results were excellent. I do not represent OWI, Old World Industries (makers of PEAK, Final Charge, Fleet Charge). There is one drawback to Final Charge in that if you do testing of engine coolant to see if the DCA level is adequate, you will find that conventional coolant test strips do not work with this coolant. Not Fleetguard, nor Penray, nor any of the common test strips that measure the Nitrite or Nitrite/Molybdate level in coolants. FC does not use nitrite and only a trace of molybdate. Still, it does its job. You just have to be very careful that you top off low coolant levels (replacing leakage loss) with the same coolant. There are other OAT coolants such as Caterpillar ELC, ChevronTexaco Delo ELC, Shell Rotella ELC, and *Dexcool. If your engine does not use silicon rubber gaskets or Buna N O-rings, you have no issues as far as elastomers. But those coolants do use conventional inhibitors, nitrite and molybdate. These OAT coolants must have the nitrite and molybdate to achieve satisfactory cylinder wall cavitation pitting protection. *Dexcool, on the other hand, does not contain nitrite and molybdate therefore it is not a heavy duty diesel coolant. The concern I always have when people talk about using an ELC coolant is that Dexcool will be chosen. You can expect the engine to fail from liner pitting or cylinder wall pitting on parent bore engines when Dexcool is used. Parent bore designs have the bores cast into the block like the PowerStroke engines, Caterpillar 3208. and Cummins B5.9 or ISB. One other thing you need to be aware of with Final Charge, measuring the freeze point accurately. Since Final Charge premix contains about 9.5% organic acid content, it measuring with the usual hydrometers will yield a freeze point that is not -34*F for a 50/50 premix. If you use a refractometer to measure freeze point, you have not much better luck in getting an accurate reading. Typical freezepoint readings for this coolant are about -40*F. It really is not that reading but it will actually be around -29F+/-. Other than that, no issues. But if you are used to testing, this stuff will break you of that habit.:)
   / Antifreeze- is any type OK? #77
Is there a test for the Final Charge coolant since you can not use conventional test strips? Do they have a test kit like Caterpillar has, the little chemistry set with a bottle of sulfuric acid or is there no way to test it other than a lab analysis?
Coolant has gotten to be a sore subject with me over the last couple of years. Having been a OTR truck mechanic for years I came to the conclusion that there are just to many types of coolant. Green, red, pink, yellow/gold, blue, purple, orange, no/low/high silicate, conventional or ELC and on and on. And then you have Cummins with their little bottle of Silicate additive we had to put on some engines. As if the poor mechanic has nothing better to do than keep a data book just on coolants so he doesn't contaminate a system with the wrong coolant. I will have to say one of the dumbest things I have ever seen (next to a spark plug in a diesel engine like the new Caterpillars have for their DPF system) is the blue colored coolant I have seen in some Cummins engines. I don't have enough fingers on my hands to count the number of cooling systems I have seen that had their coolant topped off with windshield washer fluid because the driver thought it was the washer bottle. Thank God I'm in the lubricants industry now, it's so much easier. :) For the few peoples trucks I still work on I stock only two coolants. Fleetguard conventional SCA type and Caterpillar EC1. If I am not sure what is in it they get flushed and refilled with one of these and then with a huge paint marker write on the overflow bottle what is in it so the next guy isn't left scratching his head.
   / Antifreeze- is any type OK? #78
Diesel Power, let me address some of your concerns. Let me state that I am a specialist with engine coolants, coolant chemistry and associated maintenance. Have been for 19+ years. I have seen all those changes you speak of over the years. Yes, the coolant industry (blenders and engine companies) have managed to change something relatively simple into what amounts to mostly marketing and sales rather than leading edge technology.
Old World Final Charge does have a special test kit for that coolant. While I have seen the kit, I have not had the opportunity to see what it tests for. A vendor company that makes our conventional test strips was working on test strips that could detect organic acid inhibitors. What is not known now is if those strips are chemistry specific or just measure OAT in general.
Per your comment about Cummins and the bottle of silicate fluid, Cummins did not furnish that. The original issue that brought that about was Texaco OAT extended life antifreeze formulated with ethyl hexanoic acid (EH). That acid turned out to be the cause of a major gasket failure issue for Cummins and to some degree on Caterpillar. That OAT acid attacked silicon rubber and Buna Nitrile O-rings. The silicon backbone molecular chain was destroyed causing the elastomer to shrink allowing coolant leaks. Normally, silicon rubber gaskets remain pliable for years and are "gap filling". It was determined that if a silicate film could be applied to those gaskets before the Texaco ELC coolant was installed into the system, the silicon rubber had a much longer service life. Originally, Texaco, then Shell and later ChevronTexaco supply the silicate fluid. For engines that do not use silicon rubber or Buna N elastomers the silicate fluid is not needed. An interesting side note is that while International Truck was installing the silicate fluid into Class 8 road tractors they built with Cummins ISX engines filled with International's standard factory fill (Shell OAT), it did not occur to them that they needed to do the same for some DT466 and DT530 engines filled with the same coolant. They learned they needed to have the silicate fluid as well. There was no problem of long gasket life in Cummins and International when filled with conventional chemistry coolant. Then along comes Texaco to upset the status quo. Sometimes "new and improved" is not such a good thing.
I'll ignore that comment about blue coolant :) But I will say that drivers of trucks often have difficulty checking the oil, especially fleet drivers. Owner operators are much more in tune with their trucks. If they do not know, they can suffer great monetary loss from ignorance. Fleet drivers just do not give a flip as somebody else has to fix what they mess up.
As for stocking two coolants, one conventional chemistry like the Fleetguard product you mention (ES Compleat? or ??) and the Caterpillar ELC. The issues with Cummins engines and silicon elastomers are still with us. If someone have a coolant that they are at least sure is NOT one of those OAT formulas I mentioned earlier, then topping off or refilling with the Fleetguard is an acceptable practice even if the coolant is not the same color. The colors of coolant per the coolant manufacturers is largely a matter of brand recognition. The TMC has enacted a coolant color standard as a way of identifying the coolant chemistry used. Many manufacturers have not adopted that standard. Only Shell has to my knowledge. Mixing of conventional and OAT chemistry is not really a problem, not like the problem that one company or another will state. When coolant companies say things like that, they are trying to scare customers and promote more sales.
What is the difference between OAT and Conventional?
OAT
ethylene glycol base
organic acid corrosion inhibitor (3 - 10%)
nitrite
molybdate
defoamer & dye
no silicate
no buffers (antacid additive)
little reserve alkalinity
Conventional
minimal use of organic inhibitors (<1%)
nitrite (cavitation protection)
molybdate (cavitation and aluminum protection) (not used in
Fleetcharge and some others)
defoamer & dye
low silicate levels per ASTM D4985
buffers, borate and/or phosphate
generous reserve alkalinity
There is more to this story as to what each of these chemical additives do but suffice it to say that mixing them has NO dire consequences. The worst effect you get is that when two dyes are mixed the resulting color sometimes is not so good to look at. Like mixing green kool aid and red kool aid resulting in a brown to black liquid. Just close your eyes and take a drink.....it still tastes like kool aid. Engine coolants are the same. The no mix story is just baloney made up by marketing and sales people.
One last note, you are thankful that you are in the oil business. Me, I am thankful I am not as it is easier to differentiate coolants and SCA than to show the differences in lubricating oils. At least to me that is how I view it. Glad you are there for the lube oil end of the business.
   / Antifreeze- is any type OK? #79
I was going to put off flushing and changing my BX24's antifreeze for its 300hr / 2yr service, but after reading these posts and seeing pics of the junk flushed out of some of the systems, I ran out and bought a bottle of flush and some of that $5/gallon Final Charge Global antifreeze at wally's. Pretty cheap compared to the possible future costs. Read, comprehend and learn I guess.
   / Antifreeze- is any type OK? #80
FleetServiceEngineer THANKS FOR THE INPUT.
Can I ask a question like this?
This is the product I wish to use:
Fleet Charge Antifreeze
I would like to use this in:
Kubota Diesel engines from 2 cylinder thru 4 cylinder (5 different engines)
Volkswagen Diesel TDI engine 2004 model year.
Ford (International) Powerstroke year 2000
Case Diesel 580K engine.
1) What would your opinion be?
2) This antifreeze is PURPLE, would other regular Green std/low silicate antifreezes mix with it in a pinch?
3) Would I be able to use the Ford SCA additive fw-16 to supplement this as required by test strip results?
4) What would the correct test strips be? Certain Manufacturer????
I've read everything in this post and appreciate all the material supplied, but after all the discussion, I'd still like someone to answer these 4 questions.
thanks
Frank
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55314)
2025 Wacker Neuson...
2003 Big Tex 10PI...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2020 KUBOTA SVL75-2 SKID STEER (A52706)
2020 KUBOTA...
FAKE (A52472)
FAKE (A52472)
