Any tips for removing a pin from the backhoe ?
   / Any tips for removing a pin from the backhoe ?
If it's froze up in the center it'll need some "Florida Summer Sunshine in a Bottle" (oxy-acet torch)......:thumbsup:
Get that done in the warmer weather, could have done with a torch today to free the bottom pin off, got it done with a blowtorch:)
   / Any tips for removing a pin from the backhoe ? #32
This illustration from my mini-excavator parts book shows how the flag pin is supposed to hold the pin from rotating so all movement is between the pin and bushing. Looks like when your pin seized in the bushings it really wallowed out the holes. You have your work cut out for you building that back up.
  • Mini Stick.pdf
Thanks for that, most informative.
I'll look forward to cutting , grindong , drilling , swearing etc but I suppose it has to be done, but after we dig the drainage trench:)
ONLY GONE AN DONE IT..............WAHOOO.:thumbsup::thumbsup::D:D
Found a piece of solid bar just smaller that the pin and cut a piece off about 3" long
Brother Edd held this over the pin with a pair of tongues whilst brother John whacked it with a sledge hammer.
Second strike it started to move and we were able to drift the pin out.:)
The pin is very worn at either end but perfect in the middle so we cleaned it and put some grease in via a new nipple and it squirted out the hole in the centre. The grooves in the pin for the gease to follow are perfect so here's what we intend to do....
We ground the flag off the end for re-use and are going to put a sleeve over each end the same size as the holes in the outer arm to take up the wear. Then reamer out the holes in the outer arm to the same size as the sleeves.
refit the pin and weld the flag back on so as we can secure it and hey presto good as new at very little cost (bits from under the bench)
Sorted:cool::cool::thumbsup:
pictures...:)
   / Any tips for removing a pin from the backhoe ? #35
Glad you were successful! It didn't sound like it was as difficult as we were all predicting.
   / Any tips for removing a pin from the backhoe ? #36
Sutol, I call my sledgehammer a special adjusting tool for making precise adjustments.
:D:D over here its a Land Rover special tool:D
   / Any tips for removing a pin from the backhoe ? #39
You need to read the entire thread.
   / Any tips for removing a pin from the backhoe ? #40
Don't force it......Get a bigger hammer..!!.....:thumbsup:
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2013 Ram 3500 Flatbed Truck (A59814)
2013 Ram 3500...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
