Anyone else hate the new light bulbs?
   / Anyone else hate the new light bulbs? #101
I knew a guy that put his old truck on "life support" on cold nights. It was a drop light under the hood and a trickle charger.
Sent from my Samsung SPH-L710 using TractorByNet
   / Anyone else hate the new light bulbs? #102
Spiker .........I agree with you totally about how "savings" from CFLs in winter fail to take into account the reduced heat that incandescents give a room. In Ontario here starting Jan 1 we are told we will no longer be able to buy incandescents, I don't believe it will happen, but I have stocked up and live close to USA border. Not that I try to heat my house with incandescent bulbs , but for example I try to keep my insultated garage no less than 36 degrees farenheit, so my paint won't freeze etc etc...... so I start a fire in woodstove every second or third day, in winter, but sometimes I just need to leave a couple lights on in the garage and that will be enough to keep it above freezing until I get around to starting a fire.
I find leaving a few lights on is far less worrying than plug in a portable heater that could spark or fry.
Yes I have a few of the new fangled ones , but they burn out quite often too. ...and trust me they don't get disposed with the "hazmatt" method, they just get buried in the regular garbage bag....I didn't ask for mercury bulbs to become the standard and it was not thought out well by the politics behind it.
As for summer I barely use lights in house in summer and sun goes down at 10 pm and thats bed time. I rarely use window airconditioner.
Check out halogen incandescent bulbs which are supposed to be available in Canada.
http://www.canada.com/technology/Government+relaxes+green+light+bulb+rules/8999547/story.html
If what you want is the heat from a light bulb, using multiple CFL's would probably give you roughly the same heat as one old energy wasting bulb without using more power. It's not like you are facing an insolvable problem.
   / Anyone else hate the new light bulbs? #103
Why are they outlawing incandescent bulbs... taking away someone's sensible choice to buy and pay for it, Maybe for a chicken house, and at the same time pushing for all vehicles to have "daytime running lights" which utterly wastes millions of gallons of polluting fuel, to power automotive lights in bright daylight?:ashamed:
   / Anyone else hate the new light bulbs? #104
:ashamed:Why are they outlawing incandescent bulbs, taking away someone's sensible choice to buy and pay for it, and at the same time pushing for all vehicles to have "daytime lights" which wastes millions of gallons of polluting fuel, to power automotive lights in bright daylight?
DRL's make a vehicle more visible.
   / Anyone else hate the new light bulbs? #106
That could be true but they run excess power off engine burn out alternators sooner too. That uses up more gas as mentioned, not sure where Gov is at on that one GM does it but I dont see it on Fords or Imports often other than some of the high end stuff that uses LED lighting so consume less power.
AS someone said about using CFLs to warm the well house, DON'T DO IT. the CFLs are poor in cold temps and are prone more to shorting out in wet areas like a well house. The Ballast and Ignition parts of these CFLs are electronics that can be damaged with running in the low temps outside unless they are made for it. No one is going to buy the more expensive outdoor versions to stick in the well house, what $0.40 cent Incandescent bulbs work well for. About 3 weeks back we bought a 12 pack of 60watt bulbs for $3.99 on sale, so got them pretty cheap! Got home and one was broken in the package (was OK in the store as I looked at them like Eggs.) Guess something crushed it in the trunk on way home lol...
I have a Heat Lamp that i put onto the tractor FEL when it gets REAL cold shine it onto the injection pump n& lines they get toasty and ole diesel fires right up. I added a block heater to the lower rad hose in-line style for 20bucks too after I was stranded at the end of the driveway in 16" of snow w -20 temps a few years ago... I got it started OK with several things including the heat lamps and used a pair of 500watt halogen work lamps under it for 30 min...
Mark
   / Anyone else hate the new light bulbs? #107
I have absolutely nothing against LED, 4'-8' fluorescent, and to a degree CFL's.
My BIG problem is being mandated to buy/not buy a certain product.
   / Anyone else hate the new light bulbs? #108
I doubt that is really true. You do many things because you are mandated to do them, and you do them willingly. If you don't see the benefits, you resist. That's human nature.
Running lights/daylight headlights contribute to safety. Not being safe on the road has costs, and I'll bet they are greater than the fuel or wear and tear on an alternator which is going around whether lights are on or not. With LED lights, that couldn't amount to much anyways.
   / Anyone else hate the new light bulbs? #109
So, have they been able to do away with the annoying 60Hz flicker that LED and fluorescent lights seem to possess? That makes my eyes tired. We use LED Christmas tree lights. They have the flicker. My wife doesn't notice it, but it's hard on my eyes. Wears me out. I try to avert my gaze whenever they come on. Perhaps they can speed up the rate to make it indistinguishable, like computer screens. I bump the refresh rate to 90Hz or more on my laptop and the problem seems to disappear.
Joe
   / Anyone else hate the new light bulbs? #111
When I worked overseas daytime light law had just passed.
The next time I was there... I noticed many cars without the lights on.
I was told their was such an uproar on two accounts...
Lower fuel mileage... especially with small engines AND the very high cost of replacing European Lamps... some well over $200 each!
   / Anyone else hate the new light bulbs? #112
Joe
Now I've met people got problems with the fluorescent lights, seem to recall how most had the problem when the crying got them out of a job of work.
You'd be so kind as to tell me how that flicker works out on a LED light I'd be real happy to learn because LED lights only work on DC electric. I know cause I've been putting a bunch of them inside my kitchen cabinets with magnet switches on the doors so they come on when the door opens. I even put in a couple strips of the LED light to run as emergency lights when the fool power company craps out cause they too dumb to trim trees.
   / Anyone else hate the new light bulbs? #113
They do, but if you plug in a Christmas tree or other LED 120VAC lights, they are only getting power half the time (being as 120BAC goes from +120volts to -120 volts 60 times per seconds in the US), so the lights are turning on and off 60 times per second (they are on for the 0-180 segment of the sine wave in the picture below and off from 180-360).
Source: File:Sine wave 2.svg - Wikipedia, the free encyclopedia
Many people (myself included) can see the flickering in a computer monitor that is running at 60 hertz, 75 hertz or higher and I am fine.
Aaron Z
   / Anyone else hate the new light bulbs? #114
As i am an electrical contractor and have to deal with this every day it seams, i do get kind of tired of all the hoopla there is surrounding LED lighting. I keep trying to get onboard with the program, but its real hard to convince anyone to use them when they hear the price. Alot of time i try to run the numbers for them and it usually works out that it will take 80 years to pay for themselves on average for the residential customer.... but maybe 7-10 years for the commercial customer.
I recently replaced my 175 watt high pressure sodium light on my shop exterior ,with a retrofit 40 watt LED package (as a test package ... so i can relate my findings to some clients). What i found was i really do love the light. No more waiting 5 minutes for the light to come up to brightness. Nice white, bright light. As bright...if not brighter than the old light. But at $126.00 for the fixture, it will officially take me 80 years to realize a payback on the light. in terms of energy savings.
Now, last month i installed six (6) 50 watt LED wall packs and two (2) 88 watt flood lights on a commercial parking lot. This owner wanted worryfree light fixture to deter vandalism. I could run all these lights on same power use as existing 400 watt wall pack that was in place. So in effect i could light 3 entire sides of the building for the price )in power) of lighting one small area. The results were amazing. VERY well lit parking and side areas of building. Owner really impressed. Cost for all fixtures was $3,410.00 plus 2 men and sizzor lift and 8 hours of labor and materials.Not cheap by any means. But cost savings over having to run 2 new circuits plus cost of conventional HID lighting offset the cost in this example. He should realize a savings in as little as 4 years over the cost to do this conventionally.
I do believe that as soon as LED's come down in cost, their use will skyrocket. CFL's will go by the wayside just as fast.
If you like incandescent lights...you better stock up now. 100 watt and 75 are already gone. 60 are to be gone next year. Personally ive stockpiled cases of 8 foot HO lamps ( I have 26 of these fixtures in use) and 65 watt par 30 lamps (recessed can lights) for use until LEDS drop in price. Ive been told that 65 watt par 30's will be gone soon also. Heck, i had trouble finding 50 watt par 20's last week.
   / Anyone else hate the new light bulbs? #115
Our dryers is on a 30 amp circuit, so worst case the dryer uses 30*120=3,600 watts per hour.
Assuming that the dryer is used on average 3 hours a day, 3*3,600=10,800 watts. Power now costs us 11 or 12 cents a KWH so lets just say 12 cents for worst case. .12* 10,800= $1.30 a day. Assuming the dryer is run 30 days a week, $1.30*30 is $39 a month.
I think $39 is a bit on the high side but I bet is in the ball park, maybe $30 a month. I think the hot water heater is costing $20-30 a month. If our average power bill is $120 then the dryer is cost 25% of our bill with the hot water heater being another 16-25%.
Later,
Dan
errr. wrongo. dryers work 240 volt. most are rated at 5,500 watts during operation
   / Anyone else hate the new light bulbs? #116
I read the first page of this thread then skipped to read this page, so forgive me if I missed something.
To me, seeing that spiral flouorescents use about a third the electricity of a conventional bulb for the same light output is a no-brainer. Just read the lumen (light) output on the container for your traditional bulb, buy equal or greater lumen output in the CFL. They're only 'dim' if you overlook this step.
I've tried CFL's everywhere and found only a couple of places I prefer conventional bulbs. One is the light in the bathroom that takes two bulbs. I put in a conventional bulb paired with a CFL because I found the CFL delay confusing when I stumble in there sleepyheaded in the morning. Otherwise the house is nearly all CFL's now.
Our utility occasionally puts their special-offer CFL's in Walgreens, Home Depot etc at $0.50 per bulb. Last time I bought four one-dozen cartons. Even with the occasional replacements needed, this should be enough to last until LEDs come down to reasonable prices.
I want to like LED's but haven't had good luck with them. A couple of years ago the Ebay Hong Kong sellers had the best prices so I tried various types. Half of these failed within a couple of months. All seemed to be misrepresented re actual lumens produced. I was disappointed and decided to wait for US LED's.
Then a LED from Home Depot, Consumer Report's top choice, seemed ideal if expensive - until I discovered it was the cause of terrific TV interference. I tried it everywhere in the house, no improvement. I've had it too long to take it back.
I put a Hong Kong 'corncob' LED with 132 tiny bulbs in the front porch light (mostly so the neighbors can see this technology is here now :)), actually because it didn't make enough light to use in a room. But one of the 132 elements died and another flickers. I don't expect it will serve any longer than a CFL. Another LED from Home Depot is in an inner hall where we leave the light on for days when we aren't home. Again, its light output wasn't sufficient for room lighting. Like they say, you can tell the pioneers by the arrows in their backs. I want LED technology to arrive but it isn't cost effective today.
   / Anyone else hate the new light bulbs? #117
Agreed. I worked for a hotel and we tried CFL spots in the canlights above the front desk (on pretty much 24x4), but the bulbs only lasted 9-12 months vs 2-3 years for a 130v incandescent and my time to change them was more expensive than the energy that they saved... Good gimmic though.
Aaron Z
   / Anyone else hate the new light bulbs? #118
I bought LED from Costco and use them...
The only complaint is they take awhile to come up to full brightness...
City just changed out all the street lights... 420,000 people live here and they said it is very cost effective.
We also pay as much as 32 cents per Kw
This is the 4th time in my lifetime they have changed out the lamps...
It went from very bright to not so bright and then to energy saver "Orange" and now to LED.
The light pattern is very different... mostly the light is focused along the street and not people's windows.
The exception is the pole at the end of the court... it illuminates both the yards to the left and right like never before.
There are some great posts here with really useful and informative info. Thank you.
   / Anyone else hate the new light bulbs? #120
Leaving house lights on all the time contributes to safety.
Putting up street lights everywhere, and leaving them on all night contributes to safety.
Driving big heavy vehicles contributes to the driver's safety.
If someone want to really defend unpopular mandates, then you have to use logic that passes the test across the board on all fronts. You can't have it both ways.
Daytime running lights causes the burning of millions of gallon of gas a year in this country. Cherry picking when to dismiss fuel wasting polluting as acceptable, in the name of some 'justifiable reason' doesn't fly with me.
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56438)
2022 Brush Wolf...
17307 (A55853)
17307 (A55853)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
