Anyone have info on a Mitsubishi MT205?
   / Anyone have info on a Mitsubishi MT205? #1
k54frog
Northern California
Mahindra 2015hst w/hydraulic top&tilt
Am considering a Mitsubishi MT205 (gray)
Can't find much info. I believe it was early 1990's.
Thanks - kenny-
   / Anyone have info on a Mitsubishi MT205? #2
It is an early 90's tractor. Not a lot have been imported. I can supply you with a parts book
   / Anyone have info on a Mitsubishi MT205? #3
I'm looking for information too, really hard to find anything on this model. No manual I've seen. Information I saw in a history compilation at a website called satohparts said that the gray market models have four-digit model numbers, sometimes two-digit, but the three-digit are not gray market. Maybe, maybe not, I don't know. Let's share anything useful discovered about the 205. Seems like a good tractor. Good luck.
   / Anyone have info on a Mitsubishi MT205? #4
The later Japanese models are 3 digit.
   / Anyone have info on a Mitsubishi MT205? #5
No. of Cylinders 3 cylinder(s)
Water-cooled Yes
Fuel Diesel
Performance: 20 HP
Rated RPM 2500 rpm
Regulated Rotations 2650 rpm
Total Displacement 1235 ccm
Bore 82 mm
Stroke 78 mm
4 Wheel Drive Yes
Forward Transmission 8 (4x2) gear
Rear Transmission 8 (4x2) gear
Reversible Drive Yes
Differential Locking Yes
Independent Side Brakes Yes
Maximum Forward Speed 14,7 km/h
Maximum Reverse Speed 10,21 km/h
Length 271 cm
Width 115 cm
Height 133 cm
Wheel Base 146 cm
Weight 837 kg
Front Gauge 83 cm
Rear Gauge 64 cm
Front Tire Size 6.00-14
Rear Tire Size 8.3-24
Adjustable Rear Gauge No
Hydraulic Positioning Yes
Rear Hitch 3 point
No. of Cardan Gears 3+1 gear
Standard PTO Shaft Yes
Rotary Tiller Yes (140 cm)
Electrically Controlled Hydraulic Yes
Hydraulic Adjustable Mounted Arm Yes
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
72" General Purpose Skid Steer Bucket (A59076)
72" General...
