Anyone have info on a Mitsubishi MT205?
   / Anyone have info on a Mitsubishi MT205? #1
k54frog
Northern California
Mahindra 2015hst w/hydraulic top&tilt
Am considering a Mitsubishi MT205 (gray)
Can't find much info. I believe it was early 1990's.
Thanks - kenny-
   / Anyone have info on a Mitsubishi MT205? #2
It is an early 90's tractor. Not a lot have been imported. I can supply you with a parts book
   / Anyone have info on a Mitsubishi MT205? #3
I'm looking for information too, really hard to find anything on this model. No manual I've seen. Information I saw in a history compilation at a website called satohparts said that the gray market models have four-digit model numbers, sometimes two-digit, but the three-digit are not gray market. Maybe, maybe not, I don't know. Let's share anything useful discovered about the 205. Seems like a good tractor. Good luck.
   / Anyone have info on a Mitsubishi MT205? #4
The later Japanese models are 3 digit.
   / Anyone have info on a Mitsubishi MT205? #5
No. of Cylinders 3 cylinder(s)
Water-cooled Yes
Fuel Diesel
Performance: 20 HP
Rated RPM 2500 rpm
Regulated Rotations 2650 rpm
Total Displacement 1235 ccm
Bore 82 mm
Stroke 78 mm
4 Wheel Drive Yes
Forward Transmission 8 (4x2) gear
Rear Transmission 8 (4x2) gear
Reversible Drive Yes
Differential Locking Yes
Independent Side Brakes Yes
Maximum Forward Speed 14,7 km/h
Maximum Reverse Speed 10,21 km/h
Length 271 cm
Width 115 cm
Height 133 cm
Wheel Base 146 cm
Weight 837 kg
Front Gauge 83 cm
Rear Gauge 64 cm
Front Tire Size 6.00-14
Rear Tire Size 8.3-24
Adjustable Rear Gauge No
Hydraulic Positioning Yes
Rear Hitch 3 point
No. of Cardan Gears 3+1 gear
Standard PTO Shaft Yes
Rotary Tiller Yes (140 cm)
Electrically Controlled Hydraulic Yes
Hydraulic Adjustable Mounted Arm Yes
More info coming soon! (A55851)
More info coming...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
