Anyone know the thread size of Kubota grease fittings?
   / Anyone know the thread size of Kubota grease fittings? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Kubota doesn't list the thread size and I don't feel like ordering one for $2.50. This would be for front axle fittings. Surely it must be some standard metric size?
I know, or think I know that most loader fittings are 1/4-28.
   / Anyone know the thread size of Kubota grease fittings? #2
I just looked at my parts manual and it only gives a part#. Buy one of the multipacks from tractor supply and use process of elimination. Always worked for me with any grease fitting.
   / Anyone know the thread size of Kubota grease fittings? #3
Probably a metric bolt thread. My BX axle has no zerks. Haven't had to replace any on the implements yet. Surprised I haven't broken one on the BH or FEL. I have multi packs of SAE, Metric, and IPS types. They could also be the drive in type
   / Anyone know the thread size of Kubota grease fittings? #4
Get the 100 pack of assorted metric sizes from Harbor Freight, Tractor Supply or Amazon. They are only $10 or so & you'll never run out of spares in all the sizes or angles.
   / Anyone know the thread size of Kubota grease fittings? #5
The typical metric grease fitting is M6
   / Anyone know the thread size of Kubota grease fittings? #6
I'm familiar with your dilemma. I also had one break. So - I simply order one of those assorted packs in both the metric and SAE thread types. NEITHER one worked - nothing fit exactly right.
I finally just took my broken zerk by the dealer, picked up a $0.35 replacement and problem solved. My only relief in this blunder was that I have 200 zerks on hand for most applications, except Kubota tractors.
   / Anyone know the thread size of Kubota grease fittings? #8
M 6.0 x 1.0
   / Anyone know the thread size of Kubota grease fittings? #9
Pretty much the right approach ! No matter where you look up the "correct" size it may not match the actual threads. Often they SEEM to match until you get in 2 or 3 turns and they bind or will go in no further, thus telling you you are using the wrong size. Buying the "100 assorted" is lesser of evils but creates a fresh problem -- now you have to sort through most of them trying to find a match. Such a pain. The industry SHOULD standardize on 2 or 3 sizes and abolish the rest. We won't live that long even if they decided to do it.
   / Anyone know the thread size of Kubota grease fittings? #10
Look on the bright side, at least the business end of the zerks are all the same!
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
2022 Ram 5500 Chassis Truck, VIN # 3C7WRNFL7NG196006 (A54865)
2022 Ram 5500...
White Metal Roof Panels (A55758)
White Metal Roof...
