Anyone mounted a trailer hitch ball on FEL?
   / Anyone mounted a trailer hitch ball on FEL? #21
I just bought a 16' tamdem trailer to haul my BX-22. I want to move it around my place with the tractor - - anyone mounted a ball to your FEL?
I've attached a photo of the trailer. It's a Lone Wolf Trailer. No electric brakes, but I'm not planning on any major hauling.
Thanks,
Jack
Here's what I did.
   / Anyone mounted a trailer hitch ball on FEL? #22
I made an attachment for my backhoe bucket, though I don't use it for towing my trailers, just to move them a short distance when they are in my way. I planned on adding a way to pin it in place, but it doesn't really need pinning for what I use it for. Just drop it onto the bucket, back up to the trailer and away I go. The trailer in the pic is an 18' car hauler and is almost to much tongue weight (with the box blade onboard), gotta be gentle or my front wheels will come off the ground.
Dang, that's cool BXTex. I'd make one too if you think 2x4's would work. Gotta take up welding in my next life.
Jack
   / Anyone mounted a trailer hitch ball on FEL? #25
Jack
Actually, I'll bet ya could fashion one from plywood and 2x4's ;)
I mean if some fella can make a wood motorcycle, why not :eek:
   / Anyone mounted a trailer hitch ball on FEL? #27
Thanks,
Jack
If you have a set of forks, put a ball on the end of the fork, or this
You can also use 3pt stuff on the front of your tractor, if you have the shidsteer setup
   / Anyone mounted a trailer hitch ball on FEL? #29
As long as we're talking wood,wasn't Japan's Mitsubishi Zero also made of Balsam wood?A formidable foe for sure.
   / Anyone mounted a trailer hitch ball on FEL? #30
This is excellent. Best solution yet, and exactly what I'd want. All I have to do is get a welder and learn how to use it first. :eek:
2016 FREIGHTLINER M2 SINGLE AXLE DAY CAB (A43004)
2016 FREIGHTLINER...
Dumpster Canister (A44571)
Dumpster Canister...
2021Case 5550 Spreader (A44789)
2021Case 5550...
2013 Kenworth T400 Palfinger 20M Forestry Grapple Truck (A44571)
2013 Kenworth T400...
ASV Posi Tool Backhoe Quick Attach (A44391)
ASV Posi Tool...
3 Ton Creep Feeder (A44391)
3 Ton Creep Feeder...
