Anyone running an EA 72" cutter on an MX?
   / Anyone running an EA 72" cutter on an MX? #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
Or comparable sized tractor?
I'm about 100% certain I can turn it just curious how it handles with the heavier blades on a fairly light 50hp tractor.
   / Anyone running an EA 72" cutter on an MX? #2
I have a MX5100 and have used my JD 6 foot rotary mower on it since I got it and it works fine. The JD is 35 years old and a heavy beast. I haven't used a EA72 so may not be of help but the MX5100 has no trouble with the old JD BEAST. I run an 84 inch finish mower tat works well too.
   / Anyone running an EA 72" cutter on an MX? #3
I also run a 72" old cutter (aka heavy) without any problems on my MX5100. If I am running on the road to the neighbors farm with it and hit a bump you can tell it is back there but otherwise don't really notice it. I also cut a LOT of STEEP hills without a problem with that cutter.
So no one is running the everything attachments brush cutter?
Interesting. Seems very solid and they are pretty reputable, maybe it hasn't been around long enough.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60460)
1990 Lufkin...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
Enmark Z Spray (A53316)
Enmark Z Spray...
