Anything but a hydro...why?
   / Anything but a hydro...why? #21
The hydro allows you to creep slowly when using attachments like a tiller or snowblower. I grew up with all geared tractors and they were not as "handy" as the hydro I have now. Sometimes I need my wife to drive me close to a building or tree when I'm in the bucket. I feel much "safer" being that the tractor is a hydro with her driving. Also, it is much more precise when positioning a post hole digger exactly where I want it. I still use the neighbors old furgason and allis wd tractors when I help him bale hay. They are just more of a pain to use unless you are out in the field.
Nailed it! Also, I like the hydro best for managing traction instead of having to feather a clutch, or while hooking up to any implement, front or rear. More expensive and, robs a little bit of power (compared to a geared tranny in the same tractor), and possibly (?) more expensive to fix if it breaks. Our hydro is so easy to operate, i taught my wife to use it safely in about 20 minutes. Because of this, I now am able to have some help when bringing logs in from the property. I can also now expect her to be able to use it in an emergency situation should one occur. Intimidation factor for the HST is very low.
Good luck making your own decision! BTW, NEVER use the bucket as a manlift.
   / Anything but a hydro...why? #22
My Kioti CK30HST has 30 engine hp and 22 PTO hp. The geared version is 30 engine hp and 23 PTO hp. That not a big difference and I don't find it sluggish in anyway shape or form.
If you are able to try the same tractor in gear and hydro configurations, you'll notice a difference in the way they put the power to the ground -- it's analogous to what you would observe comparing a car with both manual and automatic transmissions. The gear tractor will feel a lot snappier and have more pep.
The difference in PTO power due to an HST doesn't translate to the difference in wheel or "drawbar" power. That's because the power takes different paths when going through the PTO (generally live/mechanical in modern tractors) compared to going to the wheels (would be mechanical on a geared tractor, but fluid on a hydro tractor).
The HST causes a small loss in available power because the engine is independently running the transmission plumbing. That means there is less power available for everything else, including the PTO. Generally, running an HST pump results in a 1-2HP hit. You can consider that a parasitic loss of having HST plumbing attached to the engine, and it affects anything downstream of the engine, including the PTO.
There would be an additional hit from the HST on wheel or "drawbar" horsepower, since not only do we have that existing parasitic pump loss dragging on the engine, but now the actual drivetrain power is flowing through the molasses of the HST before it gets to the ground. I have no idea what the actual numbers are, but it's got to be in the 5-7% range (comparable to automatic transmissions on a car), and is definitely noticeable through the seat of your pants.
So what it comes down to is that the HST loses 1-2HP to everything, including PTO and wheels, and then there is another 5-7% loss getting to the wheels. A geared tractor would not have either of those additional losses.
   / Anything but a hydro...why? #23
Speaking of HST, gears, and shuttle shifts. The truth is that every HST I've ever seen was also a gear tractor. The ranges (2 or 3) are all changed with a non-synchronized gear transmission. One day, they will come out with a HST tractor with an electronic synchro-shuttle for changing gear ranges and I'll be first in line to buy one.:thumbsup: . . . if it ain't too expensive.;)
   / Anything but a hydro...why? #24
I grew up on heavy equipment everything except a John Deere skidder had either shuttle or power shift. The small skidder was ok with the gear tranny but not good. I rented a Komatsu dozer once and was not told it was a clutch and gear model. What a joke for doing serious work, I never even knew a clutched dozer was availible. The next day a hystat was on the job, now that is a sweet piece of equipment. From that day on everything, even my lawntractor has a hydrostat in it. I still do alot with class 7 and 8 trucks and more and more we are seeing automatics in the big rigs, less parts breakage and better on the operator. CJ
   / Anything but a hydro...why? #25
They already do:HST+ at least two choices within the range.
   / Anything but a hydro...why? #26
It's call HST+ at Kubota, and yes, it is expensive. JD has a similar version, can't remember what they call it.
Sorry, didn't see nybirdman beat me to it.
   / Anything but a hydro...why? #27
And you are probably happy as a clam.. do not EVER use a hydro tractor, especially for loader work or tight mowing or anything that requires a lot of directional changes, because all it will do is cause hate and discontent. Don't ask me how I know:eek:
James K0UA
I've used hydro's before and yes they are nice. Just not my cup of tea as I prefer geared transmissions (even on loader work).
I did think about the backhoe situation - I am one to hang over the seat and click it into gear to move forward or backwards. A clutch would make this impossible. OTOH, I usually just drag my tractor around as needed using the backhoe - my Woods 9000 can throw my L4200 around like so much tissue paper.
While snowblowing appears to be a perfect Hydro job, I'm beginning to wonder. For doing the parking areas, which are analogous to a Terry Bozzio solo in independence complexity, no doubt a hydro would be ideal setup. However, during the 1000' of grueling running down the driveway, I think my hydro-shuttle-gear (GST) is pretty good. I kind of sit sidesaddle in the cockpit so my head doesn't twist off - I think holding a hydro pedal would be impossible. If it had cruise control, however, that would be fine. I don't know if the mechanical shuttle I'm thinking about (it's an L2250) can be shifted on the fly. If not, it's out. Not being able to change gears while moving would be so impractical that I wouldn't want to operate it.
JayC
   / Anything but a hydro...why? #29
I have never driven a tractor with a Hst tranny so I can't speak to the pros and cons. I bought a lease return tractor that was big enough for my needs, at a cost I could afford and it had shuttle shift. Works fine. It is paid for. If there is a next tractor, I will have to make a choice. If Hst is anything like an automatic tranny, a bit of a bore, I will go running back to the shuttle shift.
But when my neighbor fires up his Kubota with Hst I always know because of the nasty whining noise that I can hear at 500 feet. I assume that ear protection is a good idea. Do they all whine like that?
   / Anything but a hydro...why? #30
...I think holding a hydro pedal would be impossible. If it had cruise control, however, that would be fine.
JayC
Tossing the tractor around with the bh will depend a little on the tractor. Kubota is a light tractor. My Woods BH-70x can't lift and move the back of my Kioti CK30 with loaded tires. I've never tried leaving it in neutral and pulling or pushing with the bh, that might work.
...But when my neighbor fires up his Kubota with Hst I always know because of the nasty whining noise that I can hear at 500 feet. I assume that ear protection is a good idea. Do they all whine like that?
My old JD 955 whined louder than my 2 year old, but my CK30 has no noticeable HST whine at all.
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
Toro 5000 Mower (A56857)
Toro 5000 Mower...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
1779 (A58375)
1779 (A58375)
