Are Plasma Cutters "Finicky"?
   / Are Plasma Cutters "Finicky"? #51
It's no longer that simple. I work for a large American company making products that get sent to China for assembly that then get shipped all over the world.
I wish I could buy American made all the time. But like most I just can't afford to do that. I also like to buy local however with the age of the internet I can simply make a few clicks and find what I need for much less time and gas needed to drive around. Plus I can look for reviews and other models to compare it to.
Did you look at a Thermal Dynamics of a comparable size to what you ended up getting? Now I know that not all of it is USA made, but some of Thermal Dynamics is USA made and assembled, it would be good to know where the machines were made and what percentage from each of the countries where they were made and assembled. Most of my tools are older USA made and will be here probably long after I have gone to my long home, I am not fond of this disposable wasteful society that we live in now. I intentionally pointed out that not all of the Thermal Dynamics was made in the USA because I knew if I didn't it would be mentioned in order to dismiss it as a viable machine for those looking to get a plasma cutter.
Jim Colt I wish your company great success and if there is any comparison tests done let your people run your machine, I would be skeptical of a test where my competition ran both their machine and mine also as one poster suggested. I recently saw a commercial where those two men that squalls at you were telling how many tools their tool replaced and one of the tools was a hacksaw and they showed the hacksaw blade struggling and breaking but the hacksaw blade looked like it had tape on it where the break occurred.
   / Are Plasma Cutters "Finicky"? #52
Trust me....Hypertherm puts virtually every plasma system through the same tests that we put ours through. Reason being.....each design has its advantages and disadvantages, and we need to know which systems have better features or performance output so we can make sure that that advantage does not continue!
We choose not to share the outcome of this type of testing for a few reasons....most notably, the general public does not believe in the data from tests unless the products are tested in a totally independent manor. Further....detailed data from comparative testing provides valuable information for competitors.....why give them all the details regarding why one product is superior?
Hypertherm has never claimed to have the lowest priced products, just the best performing and lowest operating cost. If the purchase price does not fit your budget...then clearly the best choice is a plasma cutter that does! Often, a used Hypertherm or other major brand is the best bang for the buck....unfortunately you do not find many used Hypertherm systems on the market.
Jim Colt Hypertherm
   / Are Plasma Cutters "Finicky"? #53
Jim Colt Hypertherm
I do trust that you do that, it would only be wise to do it. In the manner that you are talking about it would be for the companies internal use to better their product only and not for use to try and sell a product. The local welding supply houses need to keep at least one machine on hand for the customer to see and if they have one they need to know how much they want for it.
   / Are Plasma Cutters "Finicky"? #54
....Often, a used Hypertherm or other major brand is the best bang for the buck....unfortunately you do not find many used Hypertherm systems on the market.
Jim Colt Hypertherm
Not to gloat (well, maybe a little), but I just may be the luckiest guy on the forum. A few months ago I picked up a used Hypertherm PowerMax 800 for only $300. It "needed work" (hence the $400 asking price). I got it home spent 30 minutes of looking it over and blowing out the dust, making a cord/plug, setting voltage, and changing the consumables (it came with a nearly complete consumables kit, too!) to replace the electrode that had BEEN BURNED BACK 1/4" (!!), it fired up and I sliced the end off a piece of 3/8 bar like butter. The only thing I can figure is the employees at the previous owners company liked play around and use it as a light saber until it quit (they don't like firing when there's nothing to cut).
It paid for itself and more a few days later when I "unwelded" a poorly built trailer hitch that some schmuck had welded to the frame of my motorhome. Gouging welds is a fantastic ability (although my enthusiasm was slightly tempered due to it being overhead, in tight spaces laying underneath a motorhome... it's still molten metal spray, and no way to get away from it).
I'm building a snowplow for my B7100 now (the blade is a section of a 120gal propane tank), and having all kinds of fun with my plasma. I don't find it finicky at all.
A couple huge advantages:
Most parts you can pick up with bare hands immediately after cutting. Don't do that with oxy-ace!
Patterns are super easy. I've been making mine out of 1/8" pressboard doorskin scraps cut on a bandsaw, but just yesterday used a piece of thick cardboard. It doesn't burn!
Short straight cuts I just hold the guide (usually the same piece of pressboard) by hand on the material. Cutting arcs? clamp a piece of thin scrap wood with a screw poking up for the center, and another as an "arm" pivoting on the screw with a hole in the end for the torch at the radius distance... took less than a minute minutes to jig up for cutting 12" radius "C" shapes for the snowplow frame, and less than 10min to cut out 4 of them perfectly.. Probably 3 minutes of actual cutting time to whack the ends off the 24" dia LP tank and cut the 4ft body into three sections. I used a piece of tightly tied baling twine (!) as a torch guide while cutting the ends off.. OK, I had to replace the twine after I burned through it (once on each end)... but it was A PIECE OF STRING only 1/4" from the cut!. 1x1x1/8 angle was a guide for the straight runs. The cuts turned out so clean that no grinding is required.
Disadvantages - I still don't have a heat source for making things cherry red (bending metal, unsticking nuts, etc. )
It's not as portable as a torch for remote location work
I had to upgrade my air compressor (which was a good thing)
I have to exercise self control so I don't cut up usable material "just for fun".
I can't sleep at night due to thinking about how cool a CNC table would be.
   / Are Plasma Cutters "Finicky"? #55
Get a dry air supply and no. The dry air supply is the key.
Chris
   / Are Plasma Cutters "Finicky"? #56
...Disadvantages - I still don't have a heat source for making things cherry red (bending metal, unsticking nuts, etc. )...
If you have an arc welder look into buying/or making a "twin carbon arc torch" head for your welder. It is old school technology and you have to wear your welding helmet, but it will actually heat metal hotter than oxy/acetylene will. Plus, you never have to lease bottles, run out of gas at the worst time, etc. again. You can braze with it and real savy user's can even improvise tig weld with it (I am not quite that savey yet though as most of my twin carbon arc flames seem more comparable to a rosebud tip on oxy/acet.).
It is also possible to use a twin carbon arc to loosen rusty bolts without any flame damage to the surrounding areas whatsoever by simply touching the two carbon rods on the nut and then turn the welder on - it will heat the nut cherry red without a flame. A very cheap must have tool for the occasional user in my opinion. A $10 box of the carbon rods will last the occasional user years. ( The torch head can literally be made for little of nothing by using internet plans, or Lincoln and Pwr-Kraft made the best commercial models although I think Lincoln recently discontinued their torch head but used ones are available on ebay all the time. Connection to the welder is easy. Stinger clamps to one lead and the ground clamp connects to the other lead).
NOTE: A TWIN CARBON ARC TORCH IS NOT THE SAME AS CARBON GOUGING (or an ArcAir gouging system) although the twin carbon arc torch head does utilize the same carbon type rods. You can NOT cut with a twin carbon arc torch - you can only heat things with it. In essence you strike an arc between the 2 carbon rods and then use the arc/flame that is created to do your heating work. The carbon rods burn very slowly, but you must wear your welding helmet. Having the welder in AC mode actually works best as the carbon rods consume themselves evenly in AC mode. DC mode will work too but just not as well - one rod will burn twice as fast as the other one in DC mode. Early cinema used twin carbon arc technology to power large movie projectors and early anti-aircraft search lights used the same technology to project searchlights into the sky.
   / Are Plasma Cutters "Finicky"? #57
Like this?;)
I've never used one.
   / Are Plasma Cutters "Finicky"? #58
Like this?;)
Yep - that one looks like the Lincoln one. (The Lincoln is considered the best of the twin carbon arc torches and sometimes will still sell for $100 on ebay. I have an old Montgomery Wards Pwr-Kraft torch head that I paid $20 for on Craigslist - not as good as the Lincoln version but it works. I was going to build a free one using old automotive jumper cables for leads and modifying the plans on the internet, but could not even fool with it for $20).
My guess is that in the hands of an expert like you that you would end up being one of the savey user's who could even improvise tig weld with it. I have heard that many 1940's and 1950's era welders succesfully used these things on aluminum welding long before better methods came along that were affordable to the hobbyist.
Using only a Lincoln AC-225 AC buzzbox for the power source: Even a hack like me can easily control the flame well enough to heat metal with it in order to bend it or straighten things (these things can burn up to 1000 degrees hotter than oxy/acet if needed). I do not need extreme heat very often and one of these is the perfect low cost way to get that extreme heat on those rare occasions when I need it. A $10 box of rods will last a very long time. No expensive bottles to lease, no expensive gas to buy, never have to worry about running out of gas on the weekend and everywhere is closed, nor the dangers of having to store gas tanks.
Not necessarily the perfect tool for everyone, but the perfect tool for my infrequent needs and if it is all you have you make it work.
I have one. It's primitive, but it does work. Not very precise for cutting.
Kubota LX2620 (A53317)
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
