Are we running out of fossil fuels? - peak oil theory
   / Are we running out of fossil fuels? - peak oil theory #171
   / Are we running out of fossil fuels? - peak oil theory #172
You might want to do some reading about how oil was formed. The information is all out there for us to read about but in a nutshell petroleum was formed mostly by decaying plant matter which was buried under tremendous pressures inside the earth. This has been studied extensively by geologists that don't just pull this stuff out of their arse. I need to read more about it myself.
These are just theory's,there was no one present to see it happen.
How do you burry forests and plant matter in quantitys big enough and so deep in the earth to form these immense amounts of oil.
BTW,where is the salt domes coming from that they seem to find in a lot of fields,Out of tree's!?
Coal yes,oil...no,i don't buy it.
   / Are we running out of fossil fuels? - peak oil theory #173
I have heard on "Coast to Coast" a.m., that the Russians have drilled deep enough that the crude they found does not contain carbon.
That said, almost sounds scary they drill that deep.
   / Are we running out of fossil fuels? - peak oil theory #174
Bison, the plant matter that oil is made out of wasn't forests, but layers of algae on the ocean floor. The layers were miles thick formed over millions of years.
   / Are we running out of fossil fuels? - peak oil theory #176
Uh-huh. I got some ocean front property in Arizona.
   / Are we running out of fossil fuels? - peak oil theory #177
The answer is no. It is estimated that we have enough oil for about 2000 more years. Oil is the future of energy, get use to it, it's natural and clean.
HS
   / Are we running out of fossil fuels? - peak oil theory #178
Again, theory. Not something that can be tested and verified by experiment. Even a small scale experiment would include assumptions of the conditions at the time, something we simply cannot "know" with absolute certainty. True hard core observational science just doesn't apply with things that happened, or supposedly happened, when no one was around to observe.
   / Are we running out of fossil fuels? - peak oil theory #179
If that where the case then there should be mile thick layers of algae as an ongoing process as well on the ocean floor today as well.
No such thing today but a couple yards of mud and matter.
That pokes a hole in that algae therory does it!
   / Are we running out of fossil fuels? - peak oil theory #180
I would be curious as to what formed that much algae and why it hasn't happened again or why it isn't ongoing today?
Because it's only a theory that has never been proven or any evidence of it discovered, it does make it hard to comprehend that decaying algae is capable of turning into oil. Then how that oil gets forced thousands of feet into the core of the planet in some places, and left at the surface in other places. How it ended up in the middle of vast deserts and in the middle of huge contenents. How it is found along the equator in warm climates and near the poles, in freezing climates.
The carbon that is found in oil seems to me to be misleading because there does't seem to be any way to explain how it's related to anything organic. And why it isn't being formed on a continual basis if it is from organic life, which is still present and ongoing.
Is oil finite? If it is organic in origin, why doesn't this process continue today?
Eddie
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSAGE CHAIR (A58214)
2007 John Deere 5225 56HP Utility Tractor (A55973)
2007 John Deere...
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
